Disclaimer: The following is provided as a GUIDE ONLY, and neither myself, OZHONDA nor Underground Imports take any responsibility for the outcomes of someone else doing the following. You follow these steps at your own risk!
Aim: To fit a pair of DBA rear slotted discs to eg5 Hatch.
Time: 1hour or less
Required:
- Slotted discs
- Car jack
- Impact Hammer(highly recommended)
- Wire Brush
- 14mm, 12mm, 10mm sockets
- 14mm, 12mm, 10mm ring spanner
- 14mm, 12mm, 10mm open enders
- Big hammer
Info:
This is one of the easiest DIYs i have ever done, so easy you dont need a mate ro anything, with proper tools its a breeze. You know u wana do it yourself!!
Step 1:
OK jack up your car, take the wheel off and support the car accordingly.
Step 2:
Ok now get out your IMPACT HAMMER and go at the 2 screws holding the disc onto the hub. If u dont have one I doubt you will be able to get the screws out. They are cheap as chips and its always good to have lotsa tools so just go and buy one and do it right.
Step 3:
Now it the time to remove the small shield behind the rotor. It has two 10mm bolts. MAKE SURE YOU RELEASE HAND BRAKE NOW AS WELL!! No pic needed.
Step 4:
Now remove the two 12mm bolts holding on the brake caliper to the caliper bracket. Might be a little bit tight but your little sister should be able to get it off.
Step 5:
Now u need to take off the brake caliper bracket. Access the two 14mm bolts from behind the rotor.
