what is the difference between dot 3 and dot 4 ? lol correct me if im wrong.. dot4 support most of the cars and got more other fuctions.. or sth else ? :S
honda ones are dot 4 ? and also is that means use a higher boiling point flude will be better ??? im currently using dot 4 .. but im considring to change it to dot3 ... coz i want to try what is the difference between ... -_-''
Honda doesn't make DOT3 anymore, unless you get it from USA. They still use OEM DOT3 there.
You might as well go for DOT4 over DOT3. DOT4 can withstand higher temperature, and is also slightly less hygroscopic than DOT3. The only time you use DOT3 is if your seals in the brake system needs DOT3. Just check your brake resevoir cover and it'll tell you DOT3 or DOT4 or both.
