Aim: Replace your worn and probably leaking clutch master cylinder.
Required: Pliers, New cylinder, Socket set, Vice grips, bleed kit, syringe.
Steps:
1. Get under your car and look for your clutch pedal, If you got a clutch fluid in your car (Arrow) your need a new master cylinder. Now that ur going to replace it, take a closer look at your clutch pedal (Square)
2. At the top or ur pedal u will notice a 10mm golt pin [2]. Using your pliers, remove the clip going through it [1] and push the pin out [2] thus releasing your pedal from the master cylinder. Once this is done, loosen the bolts holding the master cylinder to the fire wall [3]
3. Outside the car, using a syringe, suck out any clutch fluid you can. Then unclip the hose that leads from the resivour to the master cylinder. Remove this FROM the MASTER CYLINDER (next steps picture, marked with an arrow) and using vice grips, clamp the hose to prevent leaks.
4. Remove the nut that holds hose on the top of the cylinder, and remove the hose.
5. Undo the bolts from the inside that hold your master cylinder and put in the new one. Dont tighten the bolts up yet
6. Reatach both hoses onto the new master cylinder. U may need to move the cylinder around (why you left it loose) to get that nut in there.
7. Now tighten the bolts that hold the cylinder to your firewall.
8. Put the pin through your pedal and master and dont forget the clip.
9. Bleed your clutch and your done ( http://www.ozhonda.com/forum/showthread.php?t=20212 )
Other comments: Shouldn't take more than 2 hours
