since i've changed the radiator... few weeks after that, the car would start nice in the morning when cold and it would drive good too. Temp will stay at the bottom/cold for 5 minz and then idling will slowly starting to rise 2-3 even 4000rpms and temp will be in the red then after while temp drops suddenly to normal and revs would come down few minz after that. that woud happen few times over in a day. I've changed thermostat plus spurk plugs and cables while i was at it. It was ok for few day and happens again but now it doesnt change :S. Im losing water/coolant. Can't find leaks, there wont be any coolant under the car under the car. I was hoping that it will die soon so i can do conversion but it choose wrong time :S. ANY EASY FIXES ??
And plus is there any good write up on the ed conversion with b18c/b18c2 engines. Coz if something blowz soon i'll have to act quickly.
Thanx
