Results 1 to 10 of 10
    Sep 2009
    Melbourne West
    K24 EG
    Unhappy Request: Hit and run rear bumper not flush
    Hey guys i had a hit and run done on me a couple months ago while i was asleep! LOL and i got another bumper which now because of the hit and run will not sit flush[as in pic]. Anyone know how i can fix this?
    Note my rear boot was moved less than 1cm unnoticeable unless looked at real close.
    Cheers
ID:	13038   Click image for larger version.
    Jul 2007
    JDMD15B
    14EGs/8EDs/3EKs
    Look at the points where it's not lining up, and if you can, just punch it in line..
    Sep 2009
    Melbourne West
    K24 EG
    Quote Originally Posted by tiksie View Post
    Tried that, it just seems not to push in enough on the sides/ doesn't push forward enough, my mate/mechanic doesn't seem to be able to do it so think it has to go to the panel beaters unless someone can help fix LOL
    Mar 2008
    SYD-SG-JPN-MY
    take it off completely, and put it back on.
    Sep 2009
    Melbourne West
    K24 EG
    Quote Originally Posted by kcokla View Post
    If it was that easy i wouldn't have put it on here...
    Jun 2007
    Adel
    DA3->EK1->DC2->
    sorry to hear.
    my car got done on the front bumper at the airport... was a sad sad day....
    Sep 2009
    Melbourne West
    K24 EG
    Quote Originally Posted by specialst View Post
    sorry to hear.
    I knew who it was also thats the bad part, after they did it they never came by the street again. damn junkies!
    Sep 2009
    Accord Euro CL9
    ur clips that connect ur bumper to the panel arebroken or damaged hence not holding....i had similar problems when my mum put it in the rong gear and reversed her car into my front bar...
    what u can do is go under from the inside drill sum holes and cable tie it to make it look flush. or u can take it to panel beaters. they will either replace it or use silicon adhesive which u can also try doing urself.
    Apr 2009
    02 DC5
    isnt your bumper just plastic
    so if you take it off it will revert to its natural shape
    after that, you can take a look at the screws that hold the bumper on
    they have probably been twisted, or the plastic gaskets snapped w/e
    maybe you can just replace those (screws, gasket thing)
    or go to junk yard and get another bumper for 100 bux
    good luck..
    Sep 2009
    Melbourne West
    K24 EG
    Quote Originally Posted by aznalex View Post
    good luck..
    I got the bumper for 100, i had to get rid of the hit one.
    Just removed and checked it again, i realised that a couple stuff were bumped into wrong places, i got a clamp and bent it properly but still no prevail, i got one side good now but still 1 side is a bit more out of place. Just gonna take it to a mate which is a beater and fix it. Thanks for the input though guys.
