Page 1 of 3 123 LastLast
Results 1 to 12 of 31
    What size semi slick on a 15x8" +36 6uL wheel on an em1?
    Ok so I'm thinking of getting a wider set of wheels for track. but not sure which brands will make the tire size that will suit.
    I'm thinking of maybe running a 225 up front and a 205 or 215 out back. I really like the Dunlop 03g's but the size I am after is not on their website...(I am currently using a 195 all round with a 7" wheel with plenty of clearance)
    Anyone have any advice from previous experience? or know if this setup will fit/work?
    Thanks for any help anyone can give, I want more grip!!
    -Mike
    WINTON PB: 1:36.30
    WAKEFIELD PB: 1:07.59
    Supported by: Hybrid Racing + Hardrace Australia
    MSC Performance FTW
    Oct 2006
    Doncaster, Melbourne
    ES1 Turbo, EK1
    225 or a 245
    im doin the same mike, looking to go to 6UL for the EK fronts and keep the Re30s for the rear
    for me i will be running 245 at the front and 225 at the rear
    Motor - D17 Motor - B20T
    Winton - 1:47 Winton - 1:46
    7th Gen Melbourne #1
    Account Disabled Array
    Sep 2004
    CT9A
    205-225's will fit.
    May 2005
    On OP.
    EK1,4,9
    for the rear, if u want to run 15x8 you need a 3mm spacer. with a 225 semi, if you want to dump the car you need to roll the guard and even flare it a bit
    fronts should be ok just depends on how low you want to go. i recommend rolling the front guards if ure going to run a 225.
    im using t1r 225/50 atm and had to roll and flare so sit the car nice and low
    HORSEPOWER is how hard you hit the wall.
    TORQUE is how far you go through it!
    Jan 2008
    EG5
    im using 16x7 with 215/45/16 ku36 . they hang over a little so i'd recommend using 215 for by 8's it will sit flush. not sure if they make it in the 15 inch though. but ku36s are sweet for street use and the occasional track.
    Ok I think i will run a 225 up front and a 205 out back. should be sweet for fitment. gaurds are already rolled and stretched ghetto DIY style so scrubbing, hopefully shouldn't be a problem. Will be for TRACK ONLY. My car is low but not like crazy low so that should be fine as well. Thanks for the advice guys
    WINTON PB: 1:36.30
    MSC Performance FTW
    May 2007
    MY00 DC2R
    leave your 7" rim and 195 at the rear
    then put a pair of 15x8 with 225/50 at front
    you will love it
    Honda Integra DC2R natural aspired K20A
    2010 CAMS Supersprint (NSW) Type 3B champion |EC: 1:46.9280|WP: 1:07.694|Winton: 1:38.614
    Oct 2006
    P1.5 460F/350R
    Quote Originally Posted by DNYALL View Post
    how do you actually stretch your guards?
    Quote Originally Posted by moo moo nel View Post
    you will love it
    Well I am currently running a 7" wheel with 205 all round. But i'm keen for a new look and some new rubber so a nice new set of 6UL's in 8" with a 225's and 205's sounds good to me. My current tyres still have a good 2 track days in them easy, possibly 3 but I 'want' a new look haha
    Thick metal bar with electrical tape wrapped around it (attempt to save the paint) get one person to hold it inside the guard between the tyre. Then another person to drive the car slowly forward and back while the person holding the bar slides it in the gap. The bar then flares out the guard a bit as well as rolling the lip up as well.
    Mind you, this pretty much fcked my paint right up and the guards are not exactly smooth anymore haha so if your worried about that then i wouldn't recommend this method
    When i can be bothered spending heaps of money, i'll get a re-spray and some minor panel work done and it will be sweet...
    WINTON PB: 1:36.30
    MSC Performance FTW
    Oct 2006
    P1.5 460F/350R
    so its like rolling guards, but also trying to make them protrude more?
    extreme guard rolling? lol
    would it be possible to stretch it with a guard roller or not likely?
    what is it called again when the fender lip is bent outwards to get more coverage instead of tucking it in?
    Oct 2006
    ES1 Turbo, EK1
    yesh i can flare the guards with a roller i did it to my EK u just need to be patient with doin to slowly or u can get it wrong and have a wavy fender.
    Like me :/ haha Would be tough times getting the flare bits to be turned out, to the outside i reckon. I have seen it done on an eg in the states i think.
    WINTON PB: 1:36.30
    MSC Performance FTW
