it could be your driveshafts that is worn out, or sometimes the cv boot is split open and exposed to weather and dirt going into the cv joints and damaging it. I dont know what the symptoms of a worn cv joint is but since its on the drivers side only it can very well be a possiblity, you can even check this out by yourself if you just look into the wheel and see if there is grease all over the place. Best of luck.
and plenty of space in your engine bay.
