Results 1 to 12 of 19
    Apr 2012
    New Plymouth, New Zealand
    Turbo City&EG8
    How To: Chipping Honda ECU's
    How To Chip Honda Ecu's
    I couldn't find anything on this with a quick search so I have decided to share a post I made over at NZH a while ago about how to chip ecu's.
    Tools:
    Soldering iron (15watt works well for me)
    De soldering braid
    Solder sucker
    Solder
    multimeter
    PGMFI City Turbo:
    Parts:
    Chip 27SF128,27SF256 or 27SF512 work well.
    28 pin dip socket.
    Chippable ECU:
    City Turbo T2 (108) (should work on T1 as well if you use T2 Rom image)
    Difficulty 6/10
    Method:
    Warm up your soldering Iron.
    While its warming up get some small wire cutters (finger nail clippers work too) and cut each leg of the 28 pin rom.
    Rom
    Then take a hair dryer and warm up the chip so the glue loosens and you can pull it off.
    Now take your solder sucker and remove each leg thats left in the PCB
    Make sure the holes are nice and wide open.
    Now check that none of the traces are torn and take some isotopic alcohol and clean all of the left over glue off the PCB.
    If everything checks out insert your socket and solder each pin back in.
    Check with your multimeter for any shorts between pins.
    Now insert your chip with the City Turbo T2 map (or in my case im using an ostrich 2.0)
    Data logging port:
    CN3
    No datalogging yet.
    Rom editors:
    Work in progress so far it can change the boost limiter.
    More:
    This is still a work in progress. More info and all information relating to this can be found here.
    ecureverse - Reverse engineering project for Honda City Turbo ECU - Google Project Hosting
    OBD0
    Parts:
    Chip 27SF256 or 27SF512 work well.
    28 pin dip socket.
    Chippable ECU:
    PR3
    PW0
    Difficulty 3/10
    Method:
    Warm up your soldering iron.
    Once warmed up take the de-soldering braid or solder sucker and remove the solder from the back of the stock chips pins so you can remove it. (A quicker and easier way is to just chop the legs then de-soldering them one at a time also your less likely to damage traces this way.)
    Once the stock chip has been removed make sure the holes are nice and open a bit of flux will help with soldering the socket in.
    Now insert the 28 pin socket and solder the pins into place.
    Insert your new chip into the socket making sure the notch (half moon) is the correct direction.
    Area to work with (mine is already chipped so cant show you what it looks like with stock chip and what it looks like once stock chip is removed)
    Data logging port:
    Pin-out left to right.
    1: Earth
    2: RX (receives data from computer)
    3: 5V
    4: TX (sends data to computer)
    5: Nothing
    Only Earth,RX and TX are required to data log.
    Data-logging requires a serial TTL converter.
    Rom editors:
    BRE
    Turboedit
    Data-logging programs:
    Iv only been able to get BRE to work for data-logging and limited features in my own program.
    OBD1:
    Parts:
    28pin dip socket
    2X .004UF SMD resistors
    2X .00001UF SMD resistors
    74hc373 SMD latch
    Chippable ECU:
    P05
    P06
    P08
    P30
    P28
    P74
    P75
    obd1 PR3
    obd1 PR4
    Difficulty 4/10 if latch is present 8/10 if latch isn't present.
    Image from PGMFI.org
    Method:
    If your ecu is one that doesn't have the latch present then that's the first part you should solder on. There are 2 methods for this. Either use a 10 pin solid center ribbon cable. Solder each pin and make sure there are no bridges. Then solder the ribbon cable to the chip. The other method is to solder the chip directly onto the ecu. If you have the slim 74hc373 this is quite easy, If you have the non-slim 74hc373D this can be a bit harder but not impossible. It just requires you to bend the pins in a bit. Make sure you mount the latch in the correct direction.
    Once you have the latch soldered in you want to test to make sure all the pins are connected correctly.
    Test pinout:
    ECU - Latch
    1-----20
    3-----15
    4-----12
    5-----16
    6-----19
    7------9
    8------6
    9------5
    10-----2
    11-----3
    12-----4
    13-----7
    14-----1 & 10
    15-----8
    16-----18
    17-----17
    18-----13
    19-----14
    (Pin 11 on the latch goes to pin 22 on the MCU)
    Image from QCWO.com - Home
    Once you have tested every pin and confirmed a connection you will want to solder in C91's resistor, This is right next to the latch and is a .00001UF SMD.
    Now de-solder the holes for the socket using the de-soldering braid.
    Once they are opened up solder C92's resistor in, This is on the back between the sockets pins. It is a .00001UF SMD.
    Now insert the socket in and solder up each pin make sure not to bride anything.
    Once that is done solder in C50 and C49's resistor they are on the back above the sockets pins and are both .004UF SMD's.
    Now if your ecu is a auto and your cars a manual you will want to remove RP17 and RP18 then bridge RP18 with a wire. These are in the bank of resistors on the back and just above the sockets pins.
    To enable your ecu to use your new external rom instead of the inbuilt one you will need to bridge J1 with a wire. This is on the back and to the left of C50.
    Socket
    Latch
    White is the MCU
    Data-logging port:
    Pinout top to bottom:
    5: Nothing
    4: TX
    3: 5V
    2: RX
    1: Earth
    J4 needs to be unbridged to enable datalogging.
    Rom editors:
    Crome
    Uberdata
    Hondata
    Freelog
    Hondalog
    ECU control
    Outro:
    This information is a collection of my, PGMFI.org and qcwo.com knowledge.
    It is presented as is and any damage caused by the use of this is at your own risk. This is only scratching the surface of Honda chipping.
    For more info visit
    pgmfi.org Index page
    Hondata - Honda ECU Modification and Enhancement
    The Wheel Wizard (͡๏̯͡๏)۶ Hondyno tuning
    •CRX• represent Array
    Nov 2003
    CRX+CBR250RR
    u reackon u can chip Kpro's?
    Apr 2012
    Turbo City&EG8
    Hondata stuff is best installed by a official dealer.
    Justin at RevZone is Australia's Hondata dealer.
    I only deal with Honda OBD0,OBD1 and OBD2(remaps in rare cases). Nissan OBD0 and OBD1. Holden Pre 96 and Links.
    Not that I can provide anything more then Technical support over the internet since I'm in New Zealand and don't want the hassle of anything international.
    Jul 2007
    JDMD15B
    14EGs/8EDs/3EKs
    Great work man.
    Any info on chipping RB20 ecu's ?
    Apr 2012
    Turbo City&EG8
    Chipping RB20 or most RB and SR ecus is the same as doing Honda OBD0 if its a Nissan OBD0 one. You just remove the stock 28pin eprom and solder in a socket. If its a OBD1 then youll need to get a Nistune adapter board then burn two chips in odd/even.
    There was a guy in Australia making copys of them for cheaper but I dont have his contact.
    OBD0
    OBD1
    If you have Crome here is a plugin I was working on to support Nissan code.
    Crome Nissan Support Plugin0.01f.zip
    I do have a newer version but I do not want to release it to the public.
    Oct 2011
    95 VTIR Integra
    ECU quetion
    Hey mate great work on the tut. Just a question... I've got a B18A1 ECU with hodata chip. I just bought me a VTIR 95 integra. Can I use The chipped ECU on my new car? Also, what about the VTEC function? How do I make it run VTEC?... if I can use it?
    Apr 2012
    Turbo City&EG8
    If your VTIR is OBD1 it should plug straight in.
    Which ECU does the b18a1 use? You may need to add the needed parts to convert it to Vtec. Or you could just re-chip the VTIR ecu (if its obd1) and plug the hondata into that.
    Then its just a matter of getting a base map and having it tuned for your new setup.
    I dont have enough attachment space left to write up a guide on how to convert non-vtec to vtec.
    But I have some info in my Book2 on my website.
    http://www.bmgjet.com/
    There is also another way to do it but it it requires changing your loom.
    You can use the additional outputs of the ECU with Hondata or Crome gold and set it up to trigger the vtec solenoid. It just means youll have to change the pin on the loom for vtec to match that output.
    But then youll still have the problem of the intake air bypass valve if your using the factory b18c intake manifold. So it would just be best swapping your hondata into your new ECU.
    Oct 2011
    95 VTIR Integra
    Thanks for the great info. Just 1 more question.... If I chip my ECU and install the S300 in it, where can I find a base map to flash onto it? Cheers.
    Apr 2012
    Turbo City&EG8
    Hondata forum and site has lots of basemaps.
    Just make sure its a legit S300 since some of the copy's have problems with uploading maps to them.
    you wouldnt happen to chip ECUs for people would you?, and also would a USB TTL converter work with the datalogging?
    Apr 2012
    Turbo City&EG8
    I do chip them but Im only providing this server within New Zealand.
    Yup a TTL converter works fine, Just be aware that the cheap ones arnt quick enough for tuning but they do give the information out just a bit slow.
    Oct 2011
    95 VTIR Integra
    I've got the P72 square shape ECU. I noticed that it's not on ur list of chippable ECUs. What does that mean for me getting it chipped to use S300 on?
