Hey I just recently done a jdm b18cr conversion into my 99 em1 b16a2...
Everything was fine for the last 2months but today it overheated on me! I checked water level and its fine, plenty of Coolant. If i switch the hot air on the car temp drops to normal but as soon as i turn it off the heat rocks up! So i Took the car to 101 motor cafe were the conversion was done, they check the fuse and power which was all good. The fan won't switch on which I'm guessing that's causing the over heat! DOES ANY1 know what's going on?
