Results 1 to 6 of 6
Thread: Need Help :(
    Apr 2012
    Integra
    Need Help :(
    hey guys/girls i installed my sri yesterday and found out that i had a cable connecting to the old intake that i couldn't plug into the new sri. i just need to know is it ok to drive with out the cable attached? the other side of the cable went next to the engine oil cap, i had to buy a mini air filter to cover it. can anyone tell me if its bad to drive with the cables not plugged in etc? i added in some photos to help
ID:	23019   Click image for larger version.
ID:	23018   Click image for larger version.
    Apr 2012
    Melbourne, S.E Suburbs
    05 DC5S
    What a cute mini pop filter. I'm no expert but I am pretty sure you don't "HAVE" to. But its best that you should i guess?
    Into Gundam and Anime?! Check out my business at www.facebook.com/officialgundamuniverse
    www.gundamuniverse.com.au
    Moderator Array
    Apr 2008
    '90 EF8/'94 EH9
    I think it's the breather that vents gas out and back into the intake. Don't need it. Just push it away and point it down because it may spit out a little bit of brown gas/droplets
    Nov 2010
    Some where in the world
    b18c2+T Ej8
    U have installed a small filter to the valve cover. u can connect the small cooling hose straight with out using the hard line.
    Mar 2007
    FD2 N/A what?
    Not good in the long run to have a breather running off the valve cover.
    Hook it up to a catch can or plumb it back into the intake.
    BTW its not a 'cable' but a 'breather line' or 'hose'
    i live my life full boost, one gear at a time.
    Banned Array
    Apr 2011
    Perth
    B16EG-GD3-DC2
    You should connect it. as a legality its meant to vent back into air intake and be reconsumed by the engine.
    So you do "have" to, just like you "have" to have a enclosed/secured pod.
    its just the law.
