Hi Im looking to rebuild my Honda Integra 1997 GSI (B18B2) as is burning oil. Valve Guide Seals have been replaced which has helped the problem, but is still has worn piston rings which need replacing.
I did a compression test and it was 180psi across the cylinders except one which was 150psi. What compression should the engine be running?
Is there any difference in the rebuild kits for B18B1 and B18B2? and also is there differences across Acura/Honda Engines as i was looking to purchase a complete rebuild kit from the US which is for an Accura B18A1/B18B1. Will this kit suit my car or not? If not is there any locations in sydney,NSW which someone could recommend me purchasing the kit from?
