Clutch Masters (sponsered) Honda S2000 currently holds the world record Fastest Street Legal S2000 with a pass of 8.79@158mph .
Clutch Masters cars hold aslo the record for FWD 8.92 the fastest All motor FWD .
The new series of Clutch Masters is names FX350 and it also available for the Honda K-Series (as well as for some other cars) .
Performance clutch kits for the 2002-2012, Acura/ Honda K-Series.
Clutch Masters is proud to offer the FX350 clutch line for Honda/Acura K-series applications. Clutch Masters FX350 has been tested and proven to be the best option for street applications that will see a high level of spirited driving. The beauty of the FX350 is its exceptionally smooth engagement while at the same time being able to handle an aggressive driving style. The FX350 series clutch kit includes our Hi-Leverage pressure plate, heavy-duty disc, OEM bearing, and alignment tool.
The FX350 friction disc features four large heavy-duty springs designed for durability, quiet operation and minimum clutch chatter. The disc also features the brand new Fiber Button friction material which combines longevity with durability.
Clutch Masters High-Leverage pressure plate provides an increase in clamping force while still maintaining a soft pedal feel. The High-Leverage design reduces the amount of load against the crankshaft minimizing thrust bearing wear, throw-out bearing wear, and crank walk.
