Same seller as OP and looks to be the same unit. I ordered mine on Monday and it arrived in Melbourne on Wednesday, awaiting clearance for delivery now, by customs I presume. Not a bad turn around for free delivery.
Pretty good step by step video. I also recommend getting one of those panel poppers to keep from scratching your interior panels. They are available from supercheap auto for $19. It comes in a set of 5 in different shapes and sizes.
I just bought a 2006 Euro LuxNavi.
What do I need to buy/do to get bluetooth hands free and audio streaming to work? On my Kluger it was easy 'cause there's a 3.5 mm input jack to which I just plugged in a BT dongle. I don't need iPod/iPhone connectors, just bluetooth streaming for my Android phone.
Installed... easy job in GE Jazz. Didn't actually have to drill any holes, the Jazz glovebox has a slot in the side that is perfect for putting the cables in and then ran the ipod cable behind the centre trim to the storage compartment so it's all nicely hidden.
Question though... ipod keeps charging even when the car is switched off? Do you guys have the same thing? Unlikely to flatten the car battery i would have thought but still would rather not have it charging at all unless the car is on.
I can confirm this works 100%. If you know where all the clips are it's easy as chips, a little harder if you don't. Sound quality and everything is fine, I've been using for last month and a bit now.
