OEM Honda Brake Pads avail now
Front brake pads :
EK4 / EK Gli / EG6 / EG2 delsol $125 incl GST
DC2R/EK9/BB6 $125 incl GST
DC5R/EP3R/FN2R/S2000 $125 incl GST
Rear brake pads:
92 to 2000 Civic / DC2 vtir and GSI / Delsol CRX etc $125 incl GST
DC2R/EK9 $125 incl GST
DC5R/EP3R/S2000 $125 incl GST
ACRE SUPER FIGHTER brake pads
ACRE Super Fightter pads are designed for street use with sports driving in mind, with good response for cold start and its beautiful control ability, it is perfect for most street driving weekend warriors. This pad has its all best balance with minimal brake dust, can be use on normal daily and sports vehicle driving. This is what we call the Super Street model, and it is also Acre’s new design based on their street pad technology. Super Fighter brake pads are rated 0-450 deg applicable rotor temperature and friction coefficient of 0.35-0.45μ
ACRE products are 100% MADE IN JAPAN.
Super Fighter 0-450deg (bang for bucks Street/Track day pads)
Was $175 , NOW $140 incl GST Front Pads
Was S175 , NOW $140 incl GST Rear Pads
Available for :
FN2R/DC5R/EP3R/S2000
DC2R/EK9/NSX
CL9/7
EK4 /EG6 /Delsol Crx ( Front pads only )
Spoon Twin Block and Monoblock back in stock !
Checkerd Sports new shipment arrived!
Skunk2 Alpha Series throttle bodies in stock ( B/D/F/H series engine)
Skunk2’s Alpha Series Throttle Bodies are designed to be used with factory intake manifolds as well as Skunk2’s Pro Series Intake Manifolds for bolt-on horsepower and torque gains by optimizing engine airflow, all at a competitive price. Skunk2’s Alpha Series Throttle Bodies are precision die-cast from high-quality materials and include features found in our Pro Series line, like countersunk mounting bolts, solid brass throttle plates, and idle adjustment screws for fine tuning. Each Alpha Series Throttle Body features an oversized bore, which results in significant horsepower gains throughout the powerband on naturally aspirated applications and even more on forced induction ones.
Misc OEM Honda shipment arrived.
These items are back in stock.
DC5R Primary O2 sensor
DC2R 02 sensor
DC2R/EG red stitching shift boot
DC5R front H badge
DC2R front H badge
EG/EK/DC2 clutch master cylinder
B18CR valve cover
B18CR oil sump
K20A 50 degree VTC
OEM Honda syncros for B and K series.
K and B series gearbox syncros
EG6 visor ( discontinued item)
DC5 visor
DC2 visor
DC2R jdm sway bar
EK9 jdm sway bar
B18CR red valve cover
RDA new shipment arrived
Integra DC2R front and rear slotted dimpled rotors in stock
Honda Civic EK4 and Gli/ CRX delsol / Integra vtir 262mm front slotted dimpled rotors and rear slotted dimpled rotors in stock
Honda Accord Euro CL9 front and rear slotted dimpled rotors in stock
EVO 6-9 frnt and rear slotted dimpled rotors in stock
F7 rear subframe brace arrived
EG / DC2 and EK subframe brace back in stock
Misc OEM Honda + Mugen parts arrived
Mugen :
Mugen discontinued oil cap in gold , silver , black , blue , red
Mugen B series thermostat
Mugen K series thermostat
Mugen Fan switch
Mugen reservoir cover
Mugen plate number bolts
OEM Honda
DC5S OEM Honda O2 sensor
B series valve cover seal
B series oil sump seal
B series valve cover seal kit ( spark plug seals , valve cover seal , grommet)
DBA 4000 series T3 front rotors for FN2 / EP3 / DC5R / DC5S.
In stock!
Honda Bond ( Hi temp silicone liquid gasket) back in stock
Effective from 24'c - 315'c
$19 each pick up
