Dodo Juice Home Brew Wax Kit is finally here and ready for you to make your own wax!
Originally Posted by CCP Website
The Dodo Juice Home Brew Wax Kit gives you the opportunity that you have always wanted and thought about – to create a quality carnauba wax yourself!
A unique creation from Dodo Juice is quite the normal these days, but this time they have made a DIY Wax Kit that still provides a high quality car wax. All the ratios for the waxes, oils, solvents, and special dodo juices have been calculated so all you have to do is mix the contents together and cook it up.
This Wax Kit comes in its distinctive and attractive tin packaging with all the instructions, labelling kit, glass jar and ingredients to create your own premium 250ml carnauba car wax in your own home. All you have to do is… think of a unique name for your own wax!
Dodo Juice Home Brew Wax Kit takes Carnauba Wax to another level by adding fun and still providing a great wax – we hope you will be as impressed and enthusiastic as we are about this fantastic kit.
This is the ultimate gift for yourself or anyone who loves their car
(Not suited for children under the age of 14)
Finally! We have released a super light Rotary Buffing Machine with soft start!
Available on its own here, or in a Kit with Pads & Polishers.
Originally Posted by Car Care Products dot com dot au
The new Mint ProTools Rotary Polisher has been designed and manufactured especially for the auto paint care industry.
This super light polisher weighs in at just 2.0kg allowing you to use it for hours and hours without the fatigue you get from the usual heavy old machines. It is also perfectly balanced with an ergonomic handle and grip that allows for greater operator comfort and reduced vibrations .
The Mint ProTools Rotary Polisher has a ‘soft start’ feature to provide more control and reduce any chance of sling when commencing a section. It also has a variable speed of 700 – 2500rpm with a built-in load sensing module to provide a constant speed output. This polisher offers double-reduction gearing, which provides a higher torque output and gives it even better performance and resilience for long periods of use. This unique two-level gear structure offers strong torque, which is twice that of the common single gear-set polishers.
The Mint ProTools Rotary Polisher comes with a long 5m power lead, a 5” Flexi-Edge Backing Plate, a Side Handle, even a spare set of brushes and a 12 month warranty. This Polisher is lightweight, controllable and perfect for the enthusiast wanting to step into the world of professional paint correction and polishing.
Recommended to work with 4", 5", 6" or 6.5" pads.
If you haven't tried Autobrite as of yet, or already currently an existing fan of the Autobrite Products the range has now expanded with more to arrive hopefully soon!
Check here in the Autobrite Section for the full range and remember to use your discount code if you have one!
We have now released a CCP Double & Triple Bucket Combo Kit to save you a couple quid for your Bucket Sets!
There are 2 kits available;
Double Bucket Combo Kit includes; 2 Buckets, 1 Grit Guard and 2 Stickers Labelled 'Wash' and 'Rinse'. For only $39.95
Triple Bucket Combo Kit includes; 3 Buckets, 1 Grit Guard and 3 Stickers Labelled 'Wash', 'Rinse' and 'Wheels'. For only $49.95
Duragloss Rinseless Wash is now available in store for $22.95
The new Duragloss Rinseless Wash (RW) is a very versatile product that offers solutions to washing your car without having to use lots of water, as a spray detailer and even a waterless wash. You can effectively wash your car using only 10 litres of water, which makes this a great product for all those that are limited to washing the car in basements, garages or who do not have access to a hose.
The high technology formula of Rinseless Wash captures the dirt with a lubricating Polymer, which reduces the chance of marring or scratching during the washing process. And with added Aquawax this product also adds protection or increases the durability of your existing sealant or wax, as it washes!
You can also use Rinseless Wash as a Quick Detailing Spray, simply add 75ml to 425ml of water and shake well. This can be sprayed onto a section and wiped clean with a soft microfibre to add gloss and protection, whilst removing dust and fingerprints.
Dodo Juice Bucket Sticker Set
Dodo Juice have released a 3 Sticker Bucket Set so you do not confuse which Bucket is Rinse, which is Wash and is that the Wheels Bucket?
Transform your ordinary forgotten buckets with the Dodo Juice ‘Wash, ‘Rinse’ & ‘Wheels’ Stickers.
This Pack includes 3 Stickers and is made from a seven year laminated vinyl.
The New Wheel Woolies Packs are now available!
The NEW Wheel Woolies are the ultimate tools for cleaning your wheels – inside and out. Instead of bristles, like most brushes, these offer ultra-soft polypropylene fibre heads combined with non-scratch polypropylene handles. This means that they are one of the safest and most effective ways to clean to clean your wheels.
Especially good for cleaning delicate rims, the Wheel Woolies construction is 100% metal free, making them very safe for all surfaces but as well as ultra-soft, they are ultra-durable making them very long lasting. The generous length of the handles on the medium and large Woolies makes cleaning even the deepest of wheel designs easy, while the small Woolie is guaranteed to fit into the tightest of spaces.
The NEW CCP Wheel Woolies are supplied in a set of 3 different sizes; Large, Medium and Small. You may also find that they are perfect for cleaning a number of other hard-to-reach areas on your car such as; door jams, surrounds, engine bays and even plastic grills.
Please note: this is the NEW Wheel Woolies kit with improved cleaning heads, a longer handle and up-sized head for the Medium Woolie and stiffer handles to making reaching through those deep rims easy. (It is NOT the regular Wheel Woolie Kit)
Nanolex Matte Protection Products are now available ; Protection for Vinyl Matte Wrap and Factory Matte Finishes.
These Products include a Surface Cleaner, Quick Detailer, Matte Shampoo, Spray Sealant or Long Term Sealant all for Matte Finishes.
Nanolex have bundled 2 Kits together to offer 2 types of protection -
■ Nanolex Matte Spray Kit (offering 4-6 months protection from a spray sealant)
■ Nanolex Matte Professional Sealant Kit (offering up to 36 months protection)
For the full Matte & Vinyl Wrap Range of Nanolex and other Matte friendly products please head here to our Matte & Vinyl Wrap Section on CCP's Website.
1Z Einszett ColourTec Deironising Wheel Cleaner is now available @ Car Care Products - $17.95 (less with forum discounts!)
1Z Einszett ColourTec Wheel Cleaner is a highly advanced cleaner that attacks brake dust, dirt, debris and road grime. The unique deironising formula particularly attachs and removes stubborn brake dust, dissolving them into a soluble form allowing easier removal and rinsing of your wheels.
ColourTec Cleaner has been particularly designed for European and other Prestige vehicles that are known for producing excessive amount of brake dust due to softer metal brake pads and discs. Over time this brake dust causes a corrosive effect which will deteriorate the clear coat finish on your wheels.
Using this innovative iron-dissolving wheel cleaner change your wheel cleaning ways forever, because it requires little or no agitation and you can let the product do the work for you! Of course wit less agitation and better cleaning ability this means less chance of marring or damaging the wheels during the cleaning process.
This wheel cleaner is safe for all wheel types including clear coated wheels, factory wheels, 2 piece, 3 piece, alloy, custom alloy and polished alloy wheels. This also can be used on Ceramic Brakes found on such cars as Lamborghini, Ferrari, Porsche, Lamborghini, Audi, etc.
