Results 1 to 12 of 16
    Ozhonda Trader Array
    Dec 2012
    Adelaide
    B, K gearbox rebuild kits
    We've put a couple of popular kits together for those wanting to rebuild their own gearbox. The kits are comprehensive: a lot of sellers don't include things like lock nuts, diff bearings, retainer clips, snap rings, spacer shims etc. Our thoughts are that you might as well do things properly if you're undertaking such a large job as a gearbox rebuild. We have no idea how you properly rebuild to factory specs without these items.
    Here's what you get:
    All genuine Honda parts:
    - input bearing front
    - input bearing rear
    - counter bearing front
    - counter bearing middle
    - counter bearing rear
    - 2 x diff bearings
    - bearing snap ring counter rear
    - input snap ring shim*
    - diff spacer shim*
    - countershaft spacer shim* (K series only)
    - countershaft lock nut /bolt
    - input shaft seal
    - 2 x diff seals
    - selector shaft seal
    - dust boot
    - FREE shipping anywhere in Australia
    Price:
    K series: $319
    B series hydraulic: $319
    B series cable: $299
    D series: $299
    Here's how it works: We send you out all the parts except the shims/spacers. You do your trial assemblies with the new bearings, take your measurements and then we send out the correct shim size for your application. This is the only way that you can properly assemble a gearbox with the correct bearing clearances and preloads without purchasing every shim!
    Last edited by chez00; 16-07-2013 at 08:15 PM. Reason: prices altered due to rising Aussie dollar
    Oct 2004
    www.alibaba.com
    porsche boxster
    Do you sell single bearings for g'box?
    and what brand are they
    Dec 2012
    Adelaide
    Yes, and everything is genuine Honda including bearings. PM what you're after and I'll get you price and availability.
    Aug 2010
    Integra Type R
    Can you source synchro rings for a b series gearbox??
    Dec 2012
    Adelaide
    Quote Originally Posted by 1.mile View Post
    Yes. I have a few options, pm me what you need, and for what model and I'll let you know price and availability.
    Thanks.
    Specialised Gearbox and Differential Repairs and Upgrades
    Genuine Honda Parts
    PPG, MTEC, DIMPLE
    neatgearboxes.com.au
    facebook.com/neatgearboxes
    Dec 2012
    Adelaide
    B cable and D series kits added. 2 x B kits sold this week.
    Jan 2009
    83, 85 &86 lude
    Hey Sam I have a B20A gold top prelude. It is a JDM car and I was hoping to get a rebuild kit for the Auto Box - yes I will convert it to manual when I get the manual box from NZ...
    In the mean time I believe the internals are similar if not the same as the A20A gearbox. Can you help a brother out?
    Zaahir
    1986 JDM DOHC B20A Gold Top Prelude: http://www.ozhonda.com/forum/showthr...-honda-prelude
    Want JDM? I can source it for you - PM for details
    Dec 2012
    Adelaide
    Hey mate that should be fine- what exactly do you need to replace? Pm me and I'll price you up.
    Genuine Honda Parts
    PPG, MTEC, DIMPLE
    Jan 2009
    83, 85 &86 lude
    I think the clutches are all shot so probably need a full rebuild?
    I will PM you when I pull it apart if that makes things easier?
    Zaahir
    Dec 2012
    Adelaide
    Yep I've got a listing for your trans (is your Prelude a BA1?) - I will need the transmission number as the clutches vary between early and late. The trans number should be something like 6129596.
    Jan 2009
    83, 85 &86 lude
    you are quite correct - it's a BA1 prelude.
    I have 2 transmissions - 1 is in my parts car and the other in my daily driver. I used to have listings but they were misplaced. I recall the parts being very similar to the A20 auto transmissions as I began to gather parts. Anyway, will get the number off my parts car when I go to my storage.
    Zaahir
    Aug 2009
    Front yard
    4WD 89 Concerto
    Got anything for a D series L3 4WD box? 88-91 Civic Wagon.
    OEM parts whore
