Sorry for delay in reply
Dear connorling, your profile and evidenced by your post tells me alot about what type of feral you are..... all class 'hay'!!!! ps. not your m8....
SPAMMAPS
Carburettor|Nation
Few things: piston speed at 13.000 rpm is impossible with the b18 stroke both mechanically and due to impossibility of getting air to flow that much at the b18 stoke/bore ratio.
No springs will be available to control the lift required
. The ITR springs are flattened to get the extra lift.
Compression ratio is fine as the cam overlap will bring it down to 12.5:1
Past 10.500 rpm reliably out of a b18 will cost $30k
