Was able to get motul atf VI cheaper than honda oem.
They claim compatibility with z1 and dw1 so will give that a go next time. Anyone used motul in their auto?
My Honda Legend KB1 (J35a engine) has recently done around 170k and has followed all the service schedules. The ATF was changed during the 120k service. Just checked the fluid, and the colour seemed to be brown (non-black and doesn't smell burnt). Can someone please give me some guidance as to what's the best way to approach this? I'm mindful that there could be some transmission damage and if I put in new fluid it might raise the sediments and therefore increasing the risk of damaging the transmission?
Also what ATF should I get? Would any of the ATF-DW1 equivalent on the front page do the job?
Thanks!
change it, 50,000km is nothing to worry about but it should be a red. is there a reason you think there would be problems with changing it or why you think there would be sediment?
check what your manual recommends but it should be compatible with the same fluids in the first post, DW1 is required for all new Honda trans coming out of the factory now but all older ones are able to take Z1 which is a bit thicker and cheaper.... DW1 is supposed to be backwards compatible though
Thanks!
Change fluid.then change again after 5k and again after 10k from initial service.
