Results 1 to 10 of 10
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Promote more airflow through the head
    Aim:*To have more airflow through the head because horsepower is restricted by how much air you can move through the head PERIOD.
    Required:*Round file,texta.
    Steps: This mod was done on my d16y4 and it works,so I cannot answer if it will work on b series or if u would want to do it to the b,i would but that's just me,I like to live on the edge.Those who own a d need every little bit of horse power we can get CHEAPLY.
    Background:
    Ok I Have Done all the bolt on mods including 60mm tb,port matched the stock im.
    To do this i had the stock tb bored out from 56mm to 60mm at the local machine work shop for $40 then got a 60mm butterfly plate from a b20 honda crv at the wreckers.Then calibrated the tps.
    To port match the im to the tb,the im will need to be removed.The link at the bottom of this post shows you the tool u can buy to put in your drill to achieve this. U can also use this tool on the exhaust ports as a fair bit of material needs removing.
    Next on your im,use your round file to open the 4 runners/ports from the stock 40mm to 42mm by taking off 1mm all the way round.Keep with the natural flow/lines of the runners and U will find what material needs removing. It is more the sides than the top and bottom.When measured equals 42mm high and 42mm wide.
    The next step is done with the im removed and the engine/head still in the car.
    NOW,
    The Head, intake side: The 4 ports measured 40mm by 40mm. So u want to open them up with the round file to 42mm by 42mm again keeping with the natural flow of things.U can use the texta to run a 1mm line around the ports as a guide.Also stuff a bit of a rag into the ports so no metal shavings get in there.
    The Head,Exhaust side: Height is 30mm,Width is 38mm.AGAIN,keeping with the natural flow of things I removed material.The result was 30mm by 43/44mm.Then port match the headers . Remember the rag in the ports!
    Make sure you port match your intake and exhaust gaskets too.
    Other comments:
    This mod works cause I've done it.
    Do it at your own risk and enjoy doing it.
    Sorry there's no pretty pics this time.If anything is hard to understand,ask.
    https://www.google.com.au/search?q=d...aIoBAHTNpIM%3A
    In summary, height (H) and width (W)
    IM before - H = 40mm W = 40mm
    after - H = 42mm W = 42MM
    INTAKE on head before - H = 40mm W = 40mm
    EXHAUST on head before - H = 30mm W = 38mm
    after - H = 30mm W = 43/44mm
    So this isnt porting the head as such we are just doing what is stated above to promote more airflow through the head.
    I have to admit I finished the exhaust side a few months ago and was concerned about the intake side on the head thinking I may _uck it up but in the end it felt right so I did it and it worked
    So this is a DIY porting of the throttle body to properly match intake manifold side right ?
    Just a WARNING - you MUST do this with the intake manifold OFF the engine. This is to prevent fine metal dust and swarf ending up ingested to your engine and other areas....a possible fatal scenario for your rings and block. Stay safe kids !
    Sep 2007
    Australia
    your mum
    Just a WARNING - you MUST to do this with the intake manifold OFF the engine. This is to prevent fine metal dust and swarf ending up ingested to your engine and other areas....a possible fatal scenario for your rings and block. Stay safe kids !
    yes.
    that!
    Sep 2006
    Out in Nature
    91 eg5 b16a
    I edited the post. Hopefully things are clearer.let me know.
    Brett.
    Oct 2009
    hehe
    hehe
    Beeza am i reading this right, your filling down the ports on your CYLINDER HEAD with a file, while the head is still on the bottom end?
    Oct 2011
    16 Wilkins St E Annerley
    Toyota Soarer
    I got shavings in my cylinder 4, what can I do
    Sep 2006
    Out in Nature
    91 eg5 b16a
    U of all people! U know me m8,I do what feels right.
    And it worked.
    Car runs a treat.pulls harder and at 160km/hr (track) its hard to hear the exhaust,just purring.
    Im not 'filing down' just opening up with the natural flow of the ports/runners.
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Quote Originally Posted by RenzokukenJ View Post
    I've missed Ozhonda lol
    Aug 2012
    canberra
    DC2
    Sound like you just earned yourself some extra compression so +rep.
    Can u show me how?
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Anyone done this yet? I doubt it
