Results 1 to 9 of 9
    Sep 2016
    2006 Honda Jazz
    Leaking Fluid - Help!
    Hey everyone, first post. After some help.
    I serviced my wifes 2006 Honda Jazz the other night and noticed some leaking fluid under the engine. It's an automatic L15A. Would it be CVT transmission fluid? Anything to worry about? CVT transmission fluid levels are good and was replaced 20,000km ago. It's just ticked over 190,000km.
    Any information would be appreciated, thanks.
    Jan 2016
    Accord Euro CL9
    Its a good idea to clean the area and re-observe. Maybe spray with some brake cleaner and wipe down with a piece of rag.
    By cleaning it up you can tell easier where the leaks come from.
    It may not be a leak as it could be a dribble (which wasn't cleaned) from previous oil change.
    Sep 2016
    2006 Honda Jazz
    Quote Originally Posted by Martin77 View Post
    Yep, I've wiped it down. It's not near the sump plug or oil filter. It seems like it's closer to the transmission. Just wondering what's under that shield plate. Might have to take it off and have a look.
    Jan 2016
    Accord Euro CL9
    Please let us know what you find.
    could be main seal leaking
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Is it transmission fluid or oil?
    Get a torch and check your driveshaft seals.Clean and re-check.
    If ok,it's your rear main seal.
    Sep 2006
    Out in Nature
    91 eg5 b16a
    A rear main seal is engine oil leak.They go hard and therefore leak a bit always.They dont completely F*ck out like a crank pulley seal.
    So no rush to change it.Just top the oil up from time to time.
    Wipe it down before rego check.
    Sep 2016
    2006 Honda Jazz
    Quote Originally Posted by beeza View Post
    Thanks for the advice everyone! I've wiped it down so will keep an eye out you see if it keeps leaking! Thanks everyone!
    As as I originally said before - in reference to this , jack up your car place it on jack stands and take off the lower cover and see if the fluid is coming from that area. It will collect in and around the inner face of that cover.
