Capacitor Questions
Hey guys
I got a Aeropro 1 Farad Capacitor off a mate of mine cause he owed me some dosh. My question is, I'm only runnin a small 2 channel amp ATM untill I get my Alpine Mono block to run my 2 Type R's, Would it be any use to me installing this at the moment for my little 2 channel, I'm at the understanding that I don't need one unless im pushing out alot of base. Will the cap cause my battery to run out more or will it combat this problem? Also how does it hook up cause I didn't get instructions. Black to eath and red to batt etc, but does my amp just hook up to the same wires??? just not sure guys. Thanks for the help
If you have a 2 Channel amp atm, no point wiring up the cap. It may help when you do get your Mono Block and will help stabilise the power. It will also increase the sound from your subs as the subs will be receiving maximum power from the amp.
arrowz
blz-arw001
OTO-KREW
it wont really make ur subs louder, theoretically it should deliver more power to them but i've never seen anyone actualli notice the difference, just install it if your lights are dimming with optimum volume and bass levels.
 Originally Posted by riceball
ballers like barefootbonzai can afford to spend money on his car and save for a future...
yeah, i phrased it incorrectly. it does depend on what kind of system you run. if its a basic system you wont hear much of a difference but with a much larger and more powerful system, you will definitely hear the difference in sound quality and the overall power.
arrowz
blz-arw001
OTO-KREW
Ahh ok, i think i may need one.
My tail lights are dimming badly
 Originally Posted by Flanderz
Hey guys
If your using the digital amps then they draw bugger all current anyway...
in my opinion you would better spend the money on an optima battery than a cap...
Albert Einstein Two things are infinite: the universe & human stupidity; I'm not sure about the universe.
Put your location in your profile, makes referring help easier!
might want to look at better grounding
Hope this information helps you out, and explains that the cap will do.
With the increasing number of high power Class AB and Digital amplifiers available these days, products such as stiffening capacitors are becoming increasingly popular. As subwoofers designed for incar use are optimized to perform in increasingly smaller enclosures, the relative efficiency of the driver is usually the first to suffer. This means more power is needed to produce the same volume of output, which in turn creates a greater demand on your car’s power supply. When an amplifier draws more power than potential amperes available, the power supply’s voltage starts to degrade, which severely affects sound quality and power output. As the current demand of a subwoofer amplifier is not continuous, a power reservoir such as a 1-farad stiffening capacitor can make a significant improvement to the performance of your sound system by quenching the instantaneous high-current pulses of the amplifier(s). By helping to keep the voltage more stable, they can only make improvements to the overall power and system dynamics.
That's great information crxy, cleared up quite a lot of things for me
thanks heaps for the quality info guys, very informative
another point: if your looking to gain db from it, 99.9% of the time it wont happen, it usually takes db away. have at the look at car audio australia website. theres a write up and test that shows they dont increase db. i dont see any point in it just get an optima yellow top. im running two alpine mono blocks, one per each sub and another amp for my front stage. all on stock battery and alternator and no dimming of my lights as yet. (in a 99 ek hatch)
