Aim: to make current rims look sexy
Required: 1 can of primer, 1 can of clear coat, 2-3 cans of black gloss wheel spray and some sand paper.
Currently wat it looks like
Step 1 :
So firstly we taped the lip with normal masking tape and then again with newspaper so it covers the tyre and lip.
Step 2:
after that we applied a coat of primer, couldnt be stuffed sanding down first b4 primer but is an option.
Step 3:
wait until primer drys and check if all surface has been covered, then start applying the black coat of paint like this
Step 4:
After applying a few coats of black so all is covered, wait until it is COMPLETELY dried. then apply Clear coat same as Step 3 but with the clear coat can. try to add an extra coat every 20-30 mins up to around 3-4 coats of clear coat.
when completely dried remove masking tape to uncover sexy lip
then on the car
this was my first DIY so be kind too me
big thanks to my friend Thai aka thaizeg on Ozhonda and Hai aka Haiz for the tools, u no wat it was .
