easy. drain gb fluid , Take out the driveshaft (no need to take the 32mm hub nut off , just loosen off suspension and slowly pull the drivehsaft to the side) and then shimmy out old seal , put in new seal (tap it in slowly) , reinstall and refill transmission fluid.
No , its also called the "release" bearing. Its the large bearing that your clutch pedal pushes in (via a cable or hydralic lines) which pushed onto the clutch diaphragm and disengages the clutch.
You do need to remove the gearbox to replace this bearing tho.
i did all this with a mechanic mate but replaced all the bearings but not the seals. my advise is to replace all the seals again aswell otherwise ur going to be like me and your going to have a leak out of the main shaft..Very Grrr... leak means slippery oil clutch and drips all over ur garage floor. now i have to do everything again just to get to the seals.
