Page 5 of 6 FirstFirst ... 23456 LastLast
Results 49 to 60 of 64
  1. #49
    Feb 2012
    Accord Euro CL9
    Quote Originally Posted by TbM View Post
    Its called brush on body deadener and i got it from supercheap auto, was about $30 for a tin i think
    Mine has plastic there too, you just take the arch cover off and there should be metal there, i only did the rear part of the front arch as the rest of the arch is in the enginebay so no need to reduce road noise in your engine bay, i fully coated the rear arches.
    Heres a pic to show the arch liner after ive put it back over the deadened arch.
    Sweet, thanks. If only I could rep you some more.
  2. #50
    Apr 2012
    '05 Civic
    Awesome DIY, and to be honest, that is more a more comprehensive job than I have seen come out of some 'professional' car audio stores.
    I'm about to do exactly this to my EP3 as I have a heap of gear to install in it. Just curious as to your thoughts on the Dynaxorb pads, is there a noticeable difference? The guys in the UK seem to go crazy for them, but I haven't seen them used here before now. I have a feeling that my side intrusion beam might get in the way of these, so I was considering just wrapping the beam in a layer of Dynamat and doing the inner and outer skins in the same way that you have.
  3. #51
    Mar 2011
    Brisbane Qld
    2 Tonne Ek Tank
    Quote Originally Posted by -JC- View Post
    Thats why i dont let "professionals" work on my car lol.
    This is the first time i have used the dynapads as they were recommended to me by trism, i installed it all at once with the dynamat so its hard to say what effect the dynapad has, but going from nothing to having dynamat and dynapad is a huge difference. They are quite cheap so if you want to get the best out of the speaker then might as well go for it.
    with regards to the intrusion beam as far as im aware there is no need to wrap it as its a fairly solid bar so shouldnt resonate, if its not attached to the door skin well you can skiaflex it to the skin to give the skin more support, mine was still attached well so i didnt bother.
  4. #52
    Apr 2012
    '05 Civic
    Too easy, thanks mate. I will see how I go when I pull the door trims off again. I had one off on the weekend to make a template for my spacers (which are being CNC cut this week sometime) and I noticed that the beam goes directly behind the speaker, so I was worried the Dynapad wouldn't fit directly behind the speaker, but I will have another look when I get into it proper.
  5. #53
    Mar 2011
    Brisbane Qld
    2 Tonne Ek Tank
    Np, if the beam goes directly behind the speaker then you might be better off looking at eggshell foam, thats the other thing trism recommended i could use behind the speakers, you would be able to mould this around the intrusion bar and cover the area behind the driver.
  6. #54
    Aug 2010
    Integra GSI
    THANK you!
  7. #55
    Mar 2012
    FD 1 2006 VTIL
    Any tips on stopping water from getting though to speakers after applying dynamat? did you stick the plastic weather shield with the grotty sticky stuff back on top of your dynamat after dynamatting?
  8. #56
    Mar 2011
    Brisbane Qld
    2 Tonne Ek Tank
    Quote Originally Posted by simonhaha View Post
    I havent had a problem with rain getting to the back of the speaker, if your seals are rooted and leaking you could glue a peice of plastic inside the door above the speaker to block water from hitting the back of the speaker.
    No i just covered the service holes in tape then mdf then dynamat which seals the door negating the need for the weathershield as you can see in the pic below.
  9. #57
    Mar 2012
    FD 1 2006 VTIL
    Thanks mate, this really helped a lot. I just recieeved my bulk of dynamat today. Would this be enough to do my 2 front doors and boot lid?
    and... would it be ok if i just stuck the dynamat straight over the service holes? Cant see myself using a electric saw cutting those MDF shapes
    Cheers
    Simon
  10. #58
    not sure if sticking dynamat is advisable over service holes, but wont the dynamat "move" when you crank the speakers, and not create that "airtight" seal that you are after.
    you dont even need to cut the holes to size/shape. just a small square piece and some bolts will do the job if you were that lazy
  11. #59
    Mar 2012
    FD 1 2006 VTIL
    think tape is even easier than bolts
    just that cutting wood is a pain the the buns. Dont wanna buy or go near an electric saw. Would cutting pieces off say a hard binder folder do the job? Its like semi cardboard/woodish.
    and just dynamat over it?
    ive seen people on youtube just lay dynamat right over the wholes without covering them, seems like TMB is doing more which seems right..
    or any other alternatives? Thanks guys
  12. #60
    wont tape rattle? but yes, alot easier than bolts
