I hope you are aware the whole filter has to be submerged and the whole system airtight for it to suck water up. Because water is heavier than air if the filter isn't completely submerged urge air will still come thru. But aem have a solution. It's called a cold air bypass it replaces the silicon connector somewhere higher up I.e. stock filter location., would be much easyer to just use that then replacing the whole intake
