ENGINE
Type: Liquid-cooled, DOHC, 16-valve, four-stroke four-cylinder
Capacity: 399cc
Bore/stroke: 55 x 42mm
Compression ratio: 11.3:1
Fuel delivery: Electronic fuel-injection
Maximum power: 52hp at 9000rpm
Maximum torque: 38Nm at 9500rpm
TRANSMISSION
Type: Six speed
CHASSIS
Type: Steel twin cradle
SUSPENSION
Front: 41mm Showa, adjustable for preload/TD>
Rear: Twin Showa shocks, adjustable for preload
Front brake: Twin 285mm discs with four-piston Nissin calipers (or three-piston ABS)
Rear brake: Single 235mm disc with single-piston Nissin caliper
OTHER STUFF
Wheelbase: 1498mm
Dry weight: 170kg
Seat height: 770mm
Fuel capacity: 18 litres
RRP: $9990 ($10,990 with ABS) POR
Warranty: 24 mths, unlimited km POR
Testbike supplied by: Honda MPE POR
