Page 1 of 4 1234 LastLast
Results 1 to 12 of 43
    Jan 2008
    Redbank QLD
    R34GTR,EF8 K20A
    My LS/VTEC build up
    Just thought I'd tell you guys about my LS/vtec conversion project.
    I've been collecting up the bits and pieces for the last few months now, and soon I'll be ready to do the deed!
    I'm doing this to my 89 DA9 LS tegra, as I'm into mods and engineering etc. (want more go LOL).
    The engine itself is in good nick, so it'll get new rings, bearings, balance, water pump etc.
    Just did the research on the net and this site, pros and cons, and worked out what parts are needed.
    Parts I have got so far are:
    GSR head
    GSR intake manifold, I removed the dual runner butterflies.
    New OBD1 dizzy, my car is OBD0
    OBD 0-1 conversion harness
    GSR ecu with Hondata s100 chip
    LS head gasket
    braided line and fittings for the vtec oil feed (from pirtek )
    ARP head stud kit B16A
    ARP 8mm rod bolts and nuts
    build and tune
    Getting a vtec solenoid off ebay as they are rare as hens teeth lol.
    Also want to get some second hand pr30 pistons to bump up the comp ratio to roughly 11.5:1 instead of 9.8:1 if I use stock pistons.
    I can forsee a clutch upgrade coming too!
    Not worried about the cost too much, and yes a B18C would be straight forward.
    Attachment 11344
    Attachment 11345
    Attachment 11346
    Attachment 11347
    Attachment 11348
    Attachment 11349
    Attachment 11350
    Mar 2006
    Sydney
    doorstop
    good stuff
    got any pics of the IAB plate or the inside of the runners at all?
    if she throws a CYP fault code, try reversing the orange & white wire on the end of the dizzy plug
    Jan 2008
    Sydney
    legtec @2psi
    Might wanna change your gearbox. Swap in a Short ratio B16 box.
    LS gearing is too long. Otherwise looking good.
    Never knew you could remove the dual stage thingo in that intake mani.
    Jan 2008
    Redbank QLD
    R34GTR,EF8 K20A
    Quote Originally Posted by CRXer View Post
    good stuff
    Yep, just for you lol. But I already reassembled the manifold.
    Cool I'll keep that in mind, I do have the colour codes for the connection to the obd0 loom so we'll see if it's good or not.
    I thought about the manifold and didn't want the extra stuff so I pulled it apart, cleaned it then reassembled using 26mm shorter bolts, as the butterfly assy is around 26mm thick. It all lines up too.
    Also pic of ecu and harness.
    Gearboxes, especially VTEC B series are pretty hard to grab lol. I'll try though, as the LS one is shagged anyway. Input shaft bearing, synchros etc all shagged, still works though with 130-140w oil!
Name:	dual runner.JPG
Name:	variable butterfly.JPG
    Nov 2007
    Sydney
    EP3R>AH>EK>DC2
    hehe, good luck bro.
    I want to see better times come out when the swap is done
    SPAMMAPS
    Carburettor|Nation
    Nov 2004
    Manly Yo
    ED/EG5/EP3/JAZZ
    Quote Originally Posted by SHOGUNOVDDRK View Post
    Second that
    161.4KW ATW Tuned By TODA
    EG5 JDM B16A SiR-II TURBO
    13.28@106.6mph 2.117 60ft On RE001
    Mar 2006
    Sydney
    doorstop
    ahhh,so thats what those little bastards hiding in my manifold look like........
    thx for the pics
    twas me,id prob just ditch the manifold alltogether,but will be interesting experiment none the less.
    be careful of the obd0>1 CYP & CKP sensor colour swap,dont know if its the same on the B18A but on the D16A8 it happens & the last conversion harness i dealt with actually accounted for the swap anyway,so maybe check it before u go swapping wires at the dizzy end.
    still... the CYP wires on your new dizzy look arse about anyway,but who knows how they wired it internally...
  8. #8
    Jan 2008
    Redbank QLD
    R34GTR,EF8 K20A
    Trying not to go too overboard on a budget car so thats why I'm using what I managed to find. We'll see how she goes on the tune and strip though!
    I'll let you know if the wires needed to be swapped or not!
  9. #9
    Nov 2007
    Sydney
    EP3R>AH>EK>DC2
    You also need to get roof racks for the car
    SPAMMAPS
    Carburettor|Nation
  10. #10
    Jan 2008
    Redbank QLD
    R34GTR,EF8 K20A
    Lol, might just leave them off for this one lol!!!! You need em on your beast, helps with aerodynamics on 80's model civics!!!...proven already!
  11. #11
    Newcomer Array
    Oct 2006
    liverpool (NSW)
    integ DA9
    nice u gonna hav alot of fun, mate got LSVtec on da
  12. #12
    Account Disabled Array
    Sep 2004
    Sydney
    CT9A
    cool build.
