Melted ECU/Computer
Hi Guys,
I was driving home last night in my 1993 Honda Integra VTi-R, and everything was smooth in the car until it started to choke like it was out of fuel. I found out that in the fuse box in the engine bay the fuse number 15 was blown. I replaced it with a spare but the engine would not turn on it would just keep turning over. There was also a very bad smell inside the car but ALL electrics work fine.
The mechanic has said today that the ECU/Computer has melted.
Does anybody know why this has happened? Is it a common thing to happen. Like it just "happened" to go. Or is there somthing causeing this and if i replace the ecu it could happen again?
The mechanic said all elecctrics and fuel pump are fine??
What could this be?
And how much am i looking at for a new ecu??
Thanks for all your help.
NEW RIDE: S14a 200sx, exhaust, fmic, bleed valve @ 13psi, vertex kit, baby blue with gold pearl, rollin on s15 stockers
OLD RIDE : 97 lancer MR coupe...satria gti engine conversion, full exhaust system, extractors, HD clutch, lowered, rims
platez : . . . [ BL.44.ZN ] . . .
http://i29.photobucket.com/albums/c2...R/NSbanner.jpg
never heard of this before....unless your ecu has taken a huge short IE power applied directly to the chassis or ECU itself. This CAN happen if you try to jump start your car with starter cables , for example.
Try to find a known good ECU for your car , see if it fixes the issue and work from there.
Just post it on the WTB thread.
or call up some wreckers like honbits?
im guessin between $100-150 ?
Just stick to ur s14 roh ... ditch the integra !
Have you got a RSM or VAFC fitted?
I had a similar issue with my old EG, one of the boards was damaged as a result of the case touching some bits inside. This as a while back and I couldn't find a VTI manual ecu, so I had it fixed.
hey guys thank you for all the information anything more would be appreciated.
Im not sure what a RSM or VAFC is but my car is completely stock. only mod is the sound system.
And the car is manual to. So besides wreckers were else could i get an ecu?
Honda Parts (better load the trailer up with cash first though)
Wreckers up here charge $160 for ECU's.
Green block gangster
Array
Its comon, and does happen to OBDI ECU's
the cap blows and flames out, I might be able to repair your ECU. PM me
