hay
i have my self an eg4 hatch Breeze
1.5L single Carby
but i recently had plug n leads changed
ever since 1 of the leads keeps popping off
not the hole way off the plug but the rubber seal that seals it to the rocket
cover is popping up and slightly pulling the lead off the plug its not dropping the cylinder but is not running the best.
could i be leading compression around the spark plug causing it to lift the lead up enough for it to escape the plug cylinder?
