My first honda conversion and pretty proud of how neatly it came together. This is a small guideline and should not be put to practice unless you have proper electrical knowledge and other reliable system information
All the mechanical was easy and everyone knows how to.
Wiring D15B Vtec into an EG Breeze using a EFI civic harness
Shock tower plugs on drivers side is plug n play besides from the Blu/Yel or Grn/Wht but that is mentioned further down.
Shock tower plugs on the passengers side has to be separated from the rest of the car body harness and comes out going from shock tower plugs to ECU plugs and with some random inputs and outputs needed to be wired. The inputs and outputs I wired into a spare 20-pin plug which I had spare from the harness so then the harness can be separated.
A gauge cluster from any EFI EG civic will fit, as you need to the tacho and fuel warning.
The speedo/odometer and SRS airbag light can be swapped to the new EFI cluster held by screws/clips.
New wires to be run-
· IACV (Blu/Yel or Grn/Wht) needs to be wired in from grey plug under RHF dash (coming from shock tower) to A9.
· Start signal from clear plug behind the fuse box to B9
· MIL is to be wired in from grey plug above fuse box to A13
· FLR-A7 and IGP2-A25 to fuel pump relay switching coil
· Fuel pump to fuel pump relay.
· The EFI engine bay fuse box is direct bolt on and comes with a handy electrical load detector which sends out about 4.5v when headlights or demister is switched on to idle up.
· ELD from the engine bay fuse box to ECU (3 wires), Blk/Yel to ignition, Black to ground, Grn/Red to D10.
· Tacho not doesnt need to be wired, plug and play.
· Fuel warning light can be wired in if you are using an EFI tank as it has the 3rd pin (Grn/yel) at the sender to red plug above the cabin fuse box (Grn/Red) to cluster.
Wires already located in the harness of the old ECU-(there are a lot of wires there which lead to believe that you dont need to run new wires but they dont go ANYWHERE)
· D1 - B+ - Wht/Blu
· D2 IGN Blk/Yel
· D8 A/C Switch Blu/Red
· D9 VSS Yel/Blu
· D22 Brake light Grn/Wht
· B2 GND Blk
· B9 A/c Relay Blk/Red
· B10 Fan Yel/Red
these have been tested and work for me.
Wires to be switched-
· Vtec pressure switch - Passengers side shock tower 14pin plug - org/blk to blank space on the side. Then A6 to D6, pins are different in size so a spare plug with smaller pins is needed wire into D6.
Trouble I ran into-
· Coolant temp sensor Bringing on engine light and high idle. Found temp sensor resistance to be 800ohms. Should be 200-400ohms, replaced with sensor from old carby motor with resistance of 250ohms. Worked a treat.
· Idle still very high (1500) The previous owner had the fast idle screw all the way out. Then set timing after to red marking on crank with engine in service mode.
Nifty facts
· Best to change engine + gearbox oil, plugs, timing belt, tensioner, water pump if your keen, THROW OUT BEARING.
· Check gearbox fluid level!!
· Exhaust wont bolt up Simply use the old carby manifold and exhaust. Not that good performance wise but quiet asJ ensuring you swap the O2 sensor.
· Fuel lines I went through the trouble getting the lines from the EFI car. But the carby lines are identical. But the vent and return is to switched, feed is normal old 5/16. The return is then the next size down then the tank vent to charcoal canister is the smallest.
· THE TANK FROM A HATCH AND SEDAN WILL BOLT UP TO THE HATCHBACK BREEZE (remember to get the plugs).
· Intake bellow and air box can be used from almost any EG EFI civic.
· A hole is to be cut to accommodate the air box as the feed is in a different location to the old carby. But I just rigged up a temporary one J
This is the old motor
This is engine from a Dennis and purchased by Thoa and installed by yours truly
EFI tank-notice when both EFI and carby tanks are side by side the carby tank can't simply bolt in a pump as there is no hole.
Wiring went from this unmarked, stripped rat's nest
to this sorted and labeled rat's nest
to this neat separable engine loom with diagnosis connector and fuel pump switching inputs.
this is the plug I've utilised for the cars inputs and outputs.
THE FINAL PRODUCT
thanks for reading.
