Results 1 to 6 of 6
    Squeeking Clutch
    Hey guys,
    I've had this problem for a while. I don't know why when I put my foot down on the clutch pedal, I hear a squeeky noise coming out of the engine bay. Is this normal? Or is there something I can do to fix this problem - if it is actually a problem?
    Thanks in advance for all input.
    Tony.
    d e e p S i x [d6]™
    Aug 2007
    Sydney
    Honda Civic Ferio 99
    Sep 2007
    CQ
    Civic
    see if your clutch reservior is low, if low check under the dash where the clutch pedal is, behind the pedal is a clutch master cylinder, brake fluid may be leaking from there.
    In which case, you'll be up for a new one, problem solved
    refer to thread above
    WTB: EK oem JDM Visors
    I love J-Cups
    Cheers! Thanks very much guys. Never knew how that guy went with his squeeky clutch, and I've got a D17A2, do you reckon the part would be in the same vicinity as the one he pictured in that thread?
    d e e p S i x [d6]™
    Nov 2007
    In the pit
    A black one
    New clutch master cylinder and/or slave cylinder will most likely be the problem. Mine is leaking, thats next on the list
    Anyone selling a black ek1 facelift Hood (OEM)?? PM ME
    Aug 2007
    Sydney
    Quote Originally Posted by SHU-ES1 View Post
    yes i believe so
