Results 1 to 12 of 12
    Green block gangster Array
    May 2004
    twin GX160's
    DIY: DC2 Radio removal
    Aim: remove radio from a DC2 Intergra.
    Required: philips head screw driver, flat head screw driver,
    step 1
    undo the 2 x screws at the back of the center consol, one either side
    Step 2
    using a flat head screw driver gently lift the cover
    Step 3
    undo the two screws
    Step 4
    Lift the handbrake lever and lift out the center console, Remove the ash tray and Undo the two screws shown below one either side. remove the gearshift knob , turn anti clockwise
    Step 5
    Undo the two screws shown below.
    Step 6
    remove the ashtray assembly, and undo the wiring harness holding it on ( see
    blue arrow ) then remove the two scews ( green arrows )
    Step 7
    pull out console.
    Step 8
    undo the radio screws under the back of the radio
    pull the radio out, replace with new one and reinstall in revers order.
    happy stereo removal
    Disabled Array
    Jun 2004
    gone
    FS:DC2R
    Wow i thought it was more simple then that to take out radio. Good post up
    Needs more time... Array
    Aug 2003
    Sydney
    Blog Entries
    12
    Ahhh......great work John
    Got a question? Check out the FAQ - http://www.ozhonda.com/go/faq
    wow, i had mine taken out professionally and didnt even know how they did it....now i no
    (btw: some usful info- stock components as per my car was
    -head unit made by kenwood, stock 6" 2-ways by pioneer,
    and stacker by alpine) not bad for a stock system i say.
    May 2004
    twin GX160's
    some times on some Hondas, you can reach behind the dash and undo the bolts in the last photo, but its very fidly and tends to hurt your hands, ends up being quicker to do it my way even though there is more work involved, and its the way the workshop manual recommends
    hey, in my car i can just put the radio console out....is this not normal?
    as well as the lil space below it.
    May 2004
    twin GX160's
    Quote Originally Posted by kousoku
    nah its not normal its ment to be bolted in
  8. #8
    Apr 2008
    west
    DC2 VTI-R
    would a double din fit in?
    would you have to buy any extra's to get it in?
  9. #9
    Nov 2008
    Melb East Side Yo!!
    Teggy, Spada Vt
    i did mine without removing the center concole. just took off the ash tray and went from there. but that was just changing my after market head unit. later i had to go through all the steps posted by ECU-MAN too hide my cables when getting proper speakers for the car.
    -=¤§ ń Ĩ ģ ĥ ţ Ŵ ő Ł F §¤=- ™
    info worth the rep point?
    WIFE AND DOG MISSING!!!
    REWARD FOR DOG
  10. #10
    Nov 2008
    Melb East Side Yo!!
    Teggy, Spada Vt
    Quote Originally Posted by mr.hieudangly View Post
    you would need to buy a frame to mount the double din. DC2's unfortunately do not come with the casing to fit on any after market head units unlike many other cars. so even when you change your OEM head unit you would need that frame put in to hold your head unit properly.
    REWARD FOR DOG
  11. #11
    May 2004
    twin GX160's
    my 1st ever DIY on OH
    this thread brings back memories
  12. #12
    wow sp3mrz.
    i did this recently. reinstalling is a little more different - as there are no brackets to hold the aftermarekt radio unit up. u have to create a 'tab' / bracket from the back of the headunit to sit across the support bar on the dash to keep it propped up.
