Well today I'd planned on getting my Apex'i RSM and G-Sensor installed and doing a dyno run.
I also recieved my Injen Intake, Comptech Short Shift, and Hondata Heat Shield gasket from my mate in the US,( http://www.ozhonda.com/forum/showthread.php?t=16196 )and yes I avoided any import duties. He did a great job of turning it into a gift.
The other filter is a BMC double cone filter that I bought locally.
So I figured I might as well have the short shift installed while they have the console removed to install the RSM. Unfortunately they didn't have any luck getting it connected using the H-48 ECU wiring pin diagram from Defi for the CL9 ( http://www.nippon-seiki.co.jp/defi/car/list.html ), so I've yet to have it installed. (EuroAccord13 you're going to have a PM or two) I ended up just with the short shift installed (cost me more than intended as I wanted to do that install myself) but I must say I LOVE IT!!!!!!!!. The shift now I feel is the perfect length (maybe it could go a little shorter) and I can confidently shift faster and smoother between gears, especially first to second gear than with the standard shift. Getting familiar with it literally took no more than about 2mins.
I finished up with a dyno run.....and of course the printer was buggered so all I have at the moment is a photo of the locked up computer monitor displaying the results. The guy's at Mercury Motorsport are going to email me copies of the results monday.
So after 23,000+ km and with zero performance modifications besides switching to Mobil 1 (Gold Bottle) 10W-40 at the 20K service my car's putting down 115.2kW (154.5HP) to the wheels which is 4HP less than the more powerful standard TSX dyno chart obtained from www.injen.com
Not bad I guess, and I can't wait to see the results from the heat shield, and then the CAI. Dare I hope for 130+kW????.Makes me wonder what yfin's done to get 120kW
Matell
2004 GP Euro Std
Comptech Short Shifter
-----To Install-----
+Hondata Heat Shield Gasket+Injen CAI+BMC Double Cone Filter+Apex'i RSM and G-Sensor.
 so I forgot to ask which gear he did the runs in. I hope it will be indicated on the results they email me when they've got their printer working. They speed with which it built rpm was too fast for fourth.
 I felt like such a fool!!!!
