just installed the tower bar got it from last week.
here is how i do it...
P.S. i am not a professional... so if there are any mistake. pls correct me.
1. un-tight a little bit the bolts on the tower bar which holds
the blue part (both side). so you able to adjust the angle of
it when you put it in
2. un-tight these 3 bolts in your car. (both side)
3. put the bar in place
4. here are pic on the driver's side. you can see is very
close to the holes.
5. the cusco manual says you can un-tight these 2 bolts
to adjust the holes about 3mm away from the tower bar.
(but i couldnt do tat)
6. so instead move the holes, i put some felt on the holes to
stop they touch each other.
7. use your hand to put the bolts back in place (both side)
**push the silver part down and tight the screws again using your
hand until you can't turn the bolts anymore**
then now you can use tools to tight it. remember dun over tight it,
otherwise you will snap the bolt.
8. NOW tight the screws on the tower bar (both side)
9. the sticker![]()
here are some of the pic
