This was first posted by Mr Sparkle (have to love that episode of the Simpsons)
here: http://tsx.acurazine.com/forums/show...3&page=1&pp=25
For those who don't frequent that site I've posted the important bit below.
It works on the Euro, so now I have another gauge to monitor!!!!![]()
I'm going to always drive around with my coolant temp displayed...Can never have too much information!.
You can still change the temperature control whilst in diagnostic mode. The only thing to remember that's not stated below is turning the Air-Con off will exit the diagnostic mode, and it can only be entered with power off.
Have fun!!!!!
The climate control unit has a diagnostic mode that allows you to view sensor inputs that it receives. To run the sensor input display mode:
1. Turn the ignition switch off.
2. Press and hold both AUTO and DUAL buttons, and start the engine.
3. After the engine starts, release both buttons.
4. The audio-HVAC display will flash a sensor number, then value for the sensor.
5. To adavnce to the next sensor, press the rear window defogger button.
6. To cancel this mode, press AUTO, or turn off ignition.
Sensor numbers, descriptions, and display values as follows:
1. In-car temp (degrees C).
2. Outside temp (C).
3. Solar radiation sensor value (00=dark, 10=cloudy, 65=sunny).
4. Engine coolant temp (C).
5. Evaporator outlet air temp (C).
6. Driver's air mix opening (low=cool, high=warm, %).
7. Passenger's air mix opening (low=cool, high=warm, %).
8. Vehicle speed (km/h).
9. Vent temp air out (C).
