Page 1 of 2 12 LastLast
Results 1 to 12 of 15
    Mar 2005
    Sydney, Castle Hill
    integra type R DC5
    vtec controller good or bad?
    hey people. i was told that honda have set vtec at the optimum position on each car. what i mean is if you lower the revs that vtec kicks in then it will hav a big effect on top end speed and obviously vise versa thus making you run a slower time in some cases. has honda got it perfect or what do people think. is vtec controller only good in highly moded hondas?
    Oct 2004
    Melbourne
    DC2 Integra VTi-R
    i personally think its a waste of money. there are plenty of otherways to mod your car
    "Tony Stark was able to build this in a cave! With a box of scraps!"
    Wayne: Funny.. Mugsees car is also built in a cave with a bunch of scraps, also its red and gold.. interesting......
    Apr 2004
    Supercharged DC5R
    IME ... modifying the vtec engage point can add serious performace value to your car. I drive a DC5r with vtec modified to engage at 3100rpm under WOT, the torque is quite impressive compared to the mid-range torque of the stock ecu. Another difference is I have no noticable kick when vtec engages, only a very small change in sound pitch. My other engine modifications are only exhaust and intake
    In my way of thinking, if there is a noticable difference in power output between 2 cam profiles when switchover occurs, then there is room to make a smoother, more linear switchover by adjusting the vtec engage point lower. Thus producing a more drivable car.
    Aren't you running hondata davidd?? If so, you're tuning much more than just VTEC cross over and fuel correction to get your 'serious gains'.
    In terms of performance, simply adjusting the VTEC crossover will not yield any extra performance. Like you heard, the factory has already optimised the VTEC point for a standard setup.
    If you adjust air/fuel ratios and ignition timing as well however, then you can certainly improve on the factory setup. An Apexi VAFC allows you to adjust fuel along with the VTEC crossover, so tuning one 'properly' (not just VTEC point) can give good gains. I've heard B series engines gain around 10-15kw in the mid range just from a good VAFC dyno tune (and around 5-10kw up top). Would give you better bang than say a cat back exhaust IMO. Both would be around the 1k mark approx. But I dunno the VAFC(II) gains on K series.
    Personally though I'd advise you save up for a full ECU tune. Due to the engine design, the K series has heaps of potential for you to unlock from the ECU.
    Aug 2003
    Melbourne Boost Junki - Honda Turbo kits
    450kwCRX-DC2R-CBR600rr
    Copy from another post... i replied to...
    Changing the Vtec point on some engines both higher or lower can increase power by a very large factor, if you provide the correct fuel and ignition to support the early or late vtec change, and in the case of K engines cam angle as well.
    Typically those if the car is almost fully stock there is no need to change the cross over point, slightly modified cars normally +- 400rpm or so from stock, and heavily modified car’s can vary heaps. This at least stands true for B H F and D engines. With the Honda K engine even stock form lowery the vtec point by 2000 or more RPM gives huge gains….. but once you make the engine breath better with a nice set of headers you increase the point from stock.. at the end of the day it all comes down to your car your modifications and the ability to how you can have your car tuned.
    Regards James
    Feb 2005
    Sid-knee
    CityRail
    interesting reads!
    Tom says: "Now remember kids, offsets are like women... they are best in their teens."
    vtec controller can really $#%% up your engine in the long term. If you really want a vtec controller, save up abit more money to get the Apexi power FC. Follow the bang for buck if i was you.
  8. #8
    Quote Originally Posted by thanh
    ANY modification can severly feck up your engine in the short , mid and long term too - its more in the relevant tuning that can make or break any modified setup.
  9. #9
    recovering.... Array
    Aug 2004
    SyDnEy
    Nicole
    i was told that if u adjust ur vtec to say cut in earlier... u gonna get a lag ...
    like a turbo lag...
  10. #10
    Quote Originally Posted by |N|
    like a turbo lag...
    an educated guess - this happens , because only the CAM timing is altered and nothing else - so no extra fuel ,air or oil flow etc is availible at any rpm's below the stock vtec engage point. Adjust these to suit ( with a proper ECU etc) and the car should pull properly from any given "vteck" point
    *correct me if wrong* !
  11. #11
    but isnt the power fc a power flow controller... i mean the vafc is for v-tec specifically ...
    but i say that if you really want your v-tec to kick in efficiently without #$%^ing up your engine then to let the momentum up and wen you feel the need to let the cams change then to set it at that point..
    i say to early no build up and top speed will be lost
    too late and there will be no point of having the controller there in the first place ...
  12. #12
    Aug 2003
    OZH-VIC
    BLZ-ARW021
    This thread is more technical, rather than Integra based.
    *moved*
