					Honda Civic and CRX Model Info
							Heres a quick rundown on the various Civic and CRX models with power specs (89 onwards).NOTE: The specifications listed below are only estimates and to be used to gain a rough idea. OzHonda in no way guarantees their accuracy and is not responsible for any errors that may have been posted.
 3rd Gen Civic GL:
 Released: 1983-1987
 Engine code: EW2
 Engine location: Front
 Engine orientation: Transverse
 Capacity (cm3): 1488
 Fuel system type: Carb
 Maximum power: 63kW @ 6000rpm
 Maximum torque: 125Nm @ 3500rpm
 4th Gen ED Civic GL
 Released: 12/87-1992
 Engine code: D15B4
 Capacity (cm3): 1493cc
 Fuel system type: Dual Carb
 Maximum power: 74kW @ 6300rpm
 Maximum torque: 126Nm @ 4500rpm
 Compression ratio 9.2:1
 Civic SiR
 Released: 1989-1991
 Engine: 1.6L DOHC VTEC 16 valve 118kW@7400RPM
 Weight: Manual only = 1,030kg with sunroof
 Brakes: 4 wheel discs (ABS optional)
 Features: Power windows, mirrors, A/C, power steering, redesigned engine bay and nose cone, LSD optional
 Models: Hatch only.
 Civic Si
 Released: 1991-1993
 Engine: 1.6L DOHC 16 valve 96kW@6,800rpm (cutout 7,200).
 Weight: Sedan = 1,052kg / Hatch = 1,016Kg
 Brakes: 4 wheel disc brakes.
 Features: Power windows & mirrors standard
 Models: 4 door sedan / 2 door hatch.
 Civic Cxi & Gli (Gli and Cxi share the same engine with different options)
 Released: 1993-2000
 Engine1: '93-'94 1.6L SOHC 16-valve 74kW
 Engine2: '94-'00 1.6L SOHC 16-valve 88kW (Gli/Cxi)
 Code1: ?
 Code2: D16Y4
 Weight: CXI-1003kg GLI-1009kg
 Brakes: Front discs, rear drums
 Features: Power windows (factory option)
 Models: 4 door sedan, 3 door hatch or 2 door coupe.
 Civic Vti
 Released: 1993-2000
 Engine1: '93-94 1.6L SOHC VTEC 16-valve 96kW@6,800rpm
 Engine2: '95-00 1.6L SOHC 16-valve 88kW
 Code1: D16Y1, (D16Y8-VTi Coupe)
 Code2: D16Y5
 Weight: Sedan-1060kg Coupe-1029kg
 Brakes: 4 wheel disc brakes (vti coupe has rear drums)
 Features: Power windows + mirrors, drivers airbag, sunroof
 Civic VTi-R
 Released: 1995-2000
 Weight: Hatch-1105kg Coupe-1114kg
 Brakes: 4 wheel Anti-Lock Disc Brakes (ABS)
 Features: Power windows, mirrors, sunroof (not available on the Coupe) and central locking
 Models: 3 door hatch or 2 door coupe.
 Civic GLi
 Released: 2000-
 Engine: 1.7L SOHC 16 valve 88kW@6,200rpm
 Weight: Manual = 1,070kg / Auto = 1,095kg
 Brakes: 4 wheel Anti-Lock Disc Brakes (ABS).
 Features: Power windows, mirrors, airbags, CD player, A/C, LEV
 Models: 5 door sedan only.
 Civic Vi
 Released: 2000-
 Engine: 1.7L SOHC VTEC 16 valve 96kW
 Weight: 1130kg
 Models: 5 door hatch.
 Honda Crx Ballade Sports (1st Gen):
 Released:1983
 Engine:4cyl/SOHC/12v
 Code: EW2 (Carby) EW5 (Efi)
 Torque:
 Transmissions: 5speed manual/4speed auto
 Weight: 820kg
 Brakes: Front Disks, Rear Drums
 Features:Sunroof, Aircon
 Models: 2door Hatchback
 Honda Crx Si (1st Gen):
 Released:1984/1985
 Engine: 4cyl/DOHC/16v
 Code: ZC/D16A3
 Torque: 144Nm @ 5700rpm
 Transmissions:5speed manual
 Weight:820kg
 Brakes:Frond Disks, Rear Drums
 Features:Sunroof, Aircon, PowerSteering
 Models:2door Hatchback
 Honda Crx Si (2nd Gen):
 Released:1987
 Engine:4cyl/DOHC/4v
 Code: D16A8, D15A (carby)
 Torque:144Nm @ 5700rpm
 Weight:880kg
 Brakes:Front Disks, Rear Disks
 Features:Sunroof, Aircon, Powersteering, Glassroof (some models)
 Honda Crx Si-R:
 Released:1989-1992
 Engine:1.6L DOHC VTEC 16 valve 118kW@7400RPM/Redline 8200Rpm
 Code:B16A
 Compression Ratio: 10.2:1
 Torque:111lb-ft@7000Rpm
 Transmission:5speed Manual
 Brakes:4wheel disc
 Features:???
 Honda Crx (delsol):
 Released:1992
 Engine: Four cylinders, in-line, belt-driven DOHC, four valves per cylinder, all alloy, variable inlet valve lift and duration.
 Code:B16A2
 Torque:150Nm @ 7000rpm
 KW:118Kw
 Weight:1050kg
 Brakes:Front brake description:Ventilated discs
 Rear brake description: Discs
 Features:Electric windows,Electric mirrors
 Models:2door
		You may not post new threadsYou may not post repliesYou may not post attachmentsYou may not edit your posts  Forum Rules |
