Frankenstein, stroked b16a or JDM ITR b18c?
Hey guys, i keep tossing up which b-series path i wanna take on an EG Hatch.. just after some opinions and/info on the three, ive searched heaps but cant work out which would be the best for my money and which would pump out the most performace.. i like torque and it is for street only, so some reliablility would be good also.. The options im tossing up between are:
1. JDM b16a w/ b20 conversion
2. JDM b16a stroked out to a 1.8lt
3. b18c Type-R
What do u guys reckon would be the best per dollar of the three?
best dollar per hp = B20VTEC
best grin factor = B20VTEC
most logical thing to get most power = B20VTEC
easiest thing to stuff up if you have no idea = B20VTEC
B20VTEC - since 2002
get a jdm b18c type R engine, hardto find though and cost alot
what do u reckon if a professional did the B20VTEC swap, someone with experience and they strengthened it?
im starting to like this idea
i like the grin factor
have you already had this discussion with me over PM? many people have, cant remember them all...
BTW - a 'professional' will rip you off, and strenghtening of the block can be as simple as fitting new ARP rod bolts...
i think the cheapest would be to find an EG6, and use option 1 or 2..
stroked b16a is expensive too...
i havent had this discussion with u tinkerbell
thanks for the info though, so im guessing your experienced with this?
If so, which of the 3 options would u recommend if money wasnt a hassle?
im likiing this idea but am worried about the reliability side of things...
weakness:
1. thin cylinder walls due to larger bore;
2. weak rods/rod bolts due to low rpm design;
3. piston to valve clearance due to small valves in B20B.
so, using stock internals, you will not be generating sufficent cylinder pressures to risk damaging the (weaker) cylinder liners,
nor is the compression ratio high enough (~9.5:1) to really worry about detonation damaging the (weaker) sleeves,
piston to valve clearance can be solved with a hand widening of the piston reliefs with dremel or similar,
rod bolts replaced by ARP parts is best, solving the weak bolt delima,
i have revved my B20VTEC to 9200rpm a couple of times, to 8500rpm many times, over 8000rpm daily, with no broken rods, so i think the stock rods are ok, it is just the bolts that can break.
if you are in syd, pm me for a full cost breakdown...
