Green block gangster
Array
DIY JDM B18C ITR Engine Install in EG Civic
Aim: to make car go faster
Required: lots of tools, engine hoist, some hours to sleep
Steps: lots, see bellow
Other comments: dont get a cage trailer for your front cut !!!!
In this article Ill describe how to install a B18C in an EG Civic, its note quite step by step, but it should give you an idea of the work required to do such a convertion.
- its best to take the car 1st to an aircon place and have them vac out the refrigerant from the aircon system.
start by getting your front cut to the workshop. dont make the same mistake as me and get a trailer with a cage.
didnt quite fit out the front, had to sort of tilt and lift, waisted alot of time.
Removing the engine from the front cut was fun, just be carefull not to damage anything as you may need to use it in the install or you can sell off bits that are left over.
I gave the engine a bit of a pressure clean once it was out,
1. to get rid of alot of crap that was on the engine.
2. to make it look nice
Next step is to remove the engine from the EG
- Remove the bonnet, drain the gearbox oil, engine oil, coolant, power stearing fluid, and the clutch hydraulic fluid. remeber to get the aircon gas removed by a aircon place, prior to starting the job.
******** NEVER VENT R12 GAS TO THE ATMOSPHERE **********
- Remove battery, remove the radiator, Aircon Condensor, power stearing pump and resivoir, intake system. ( red circles ) splash guard
- Undo the brake booster vac line, fuel lines, heater hoses, accelerator cable, wiring loom from both LH and RH shock towers for PGMFI and ACC, air con lines from compressor. clutch slave cylinder hose, shift linkage, exhaust. earth strap from rocca and MT. batt positive terminal from fues box.
- remove drive shafts. see photo bellow
Support the engine with the engine hoist and undo the engine mounts. located roughly in blue circles above.
lift engine out, make sure there is nothing atached to the engine as you lift it out.
now its time to remove the D series rear center engine mount and the High pressure power stearing line.
I also installed a K beam support bar the front cut had on it. ( red circle in picture bellow )
Install the ITR high pressure power stearing hose as this lines up perfectly with the B18C. notice it has a pressure switch on it ( red circle above pic )
then fit the ITR Rear Center engine mount on the cross member.
I decided to give the engine bay a pressure clean at this stage to make it look nice. then where ready to drop the beast in.
do up the two center mounts to hold the engine in the bay
now do up the two lower mounts.
now do up the center rear mount, ( have fun )
no pic of this one
now its time to start connecting everything , like the power stearing, vac lines, RHS ( driver side ) engine to tower loom, fuel lines, heater hoses. earth strap at gearbox, clutch slave hose. fit air intake of your choice. all these just line right up with no mods. gotta love Honda ay
install the radiator and the condensor. you will have to ghetto the compressor hoses for the air con system, but they will bolt in to seal up the aircon system till you take it to get them modified when regassed. do up the earth strap to the rocca cover.
remove the D series shift linkage and install the ITR linkage. install both drive shafts.
replace the oil filter, and fill up the
engine oil
gearbox oil
clutch system fluid
cooant
DONT FORGET
now the engine bay all ready to go you have to wire it all up.
now the fun begins
cut the OBDII ECU connectors off the loom roughly about 30cm from the connectors.
remove your D series ECU
im not going into great detail on conecting each and every wire, but if you want and exact list of what goes where PM me.
I think its good practice to connect one wire at a time and then do a continuity test to make sure you have done it right, then move to the next wire.
you will have to run 5 extra wire to the engine bay from the ecu
- power stearing Pressure switch signal
- power stearing Pressure switch Ground
- knock sensor
- O2 heater
- VTEC solenoid
you just have to tap into the loom connector at the shock tower, then you can connect the 3 connectors there.
heres some more pics
and after 2 days of work
this bad boy started 1st pop, ran for a bit then wouldnt restart, found out the plugs where rooted so I replaced them and off she goes to the exhaust place to have the exhaust welded on properly. I just did a bit of a ghetto mod with some wire to hold it in place.
let me tell you this thig goes HARD.
just use all the ITR mounts and you wont have any problems
ECU-MAN
