				Green block gangster
				Array
					DIY ABS Bleed Type I & II
 Aim: To Bleed the ABS/ALB system
 Required: see pic bellow
 you need
 - 500ml of quality ( OEM HONDA ) brake fluid
 - surynge with a bit of vacuum hose on the end
 - long nose pliers
 - Special Honda T peice ALB Bleed tool ( 95-97 Accord you can use a 10mm spanner, DC2 as well I think )
 Steps: 1 locate your ABS or ALB system
 it should look something like this, this is a Del Sol ABS Modulator
 STEP 2: open the resivor cap and suck out all the brake fluid with the surynge.
 when you have sucked out all the fluid, fill it up to the top with brake fluid.
 STEP 3: locate the acumulator bleed nipple, blue circle, red arrow. it will have a cover ( green arrow ) remove the cover with your long nose pliers. do not loose the cover.
 STEP 4: place the T peice tool on the nipple, ensure its cap is on properly, turn the handles anti-clockwise slowly until all the brake fluid stops rushing out of the accumulator. then close the nipple.
 do not overtighten the bleed nipple.
 STEP 5: locate your ABS fues box
 lift the cover off, lift from the tab where the blue arrow is pointing.
 STEP 6: locate and remove the ABS pump relay ( blue circle )
 STEP 7: short out the two contacts that will drive the pump. on this type of set up its the two bottom contact that are closer to each other. IGN off.
 DO NOT RUN THE PUMP FOR LONGER THAN 7 sec. this will prime the Accumulator with brake fluid from the resivor.
 red circle, short out the lower two contact. ( blue line )
 STEP 8: open the T peice tool lowly anti-clockwise to allow the pressurised brake fluid escape from the accumulator. Then close the nipple.
 STEP 9: fill the resivor with brake fluid to compensate for the fluid you have just flushed out.
 STEP 10: repeate steps 7, 8, 9 until you have flushed clean fluid out into the resivor of the T peice tool. do not allow its resivour to get to full. refit your ABS pump relay. refit the bleed nipple cover. Turn the IGN on to II. Allow the ABS Pump to run if the ABS computer doesnt sens enough pressure in the Accumulator, then recheck your ABS fluid level.
 download a video of this process 2.5mb click here
 Notes:
 you might think this DIY is useless coz you dont have the special tool, well you could be right, maybe you will apriciate the service you get at your Honda dealership. ( I wonder how many non honda workshops bleed your abs correctly ). or you could make your own tool. However CD5 and DC2 owners are in luck. on cars that are ALB you need the tool. on cars that are ABS with the square sided bleed nipple, you need the tool. On cars like CD5 and DC2 you have a hex bleed nippple, and the ABS modulator is in an accessible area, you can use a 10mm spanner and a brake bleed bottle instead of the tool. make sure you hold the hose down on the nipple as you open it as pressurised brake fluid is going to come out. open the nipple slowly and only a little bit. you can regulate the amount of fluid that comes out.
 if your paranoid have the hose, sponge, suds and a bucket handy.
 Type III ABS systems most post 96 cars will have the low pressure ABS system. these ABS systems do not have an Accumulator nor a ABS brake fluid resivor. They are blead as you bleed your brakes.
 DO NOT SPILL BRAKE FLUID ON YOR PAINT WORK, IT WILL DAMAGE IT
 have fun
							wow, thats cool. nice one
							if i had ABS i would be clapping my hands now....since not , all you get is a hug John  Good work son.
							would this tool be needed on a EK coupe(ej8)
							can u write one up for cars without abs but 4 wheel disc's
 kenny
		        		VTEC+Turbo=dirty underpants
				Array
	no
					  Originally Posted by honda_b_blastn would this tool be needed on a EK coupe(ej8) 96 onwards civics have low pressure ABS ( Type III )
	so how about 94 dc2 vtir ?
					  Originally Posted by ECU-MAN no 96 onwards civics have low pressure ABS ( Type III )
				Array
							you will need to bleed it manually, like it says above. only post 96 cars are low pressure. however post 96 DC2 are still high pressure type II.
							nice writeup as per usual Uleh!
  Much appreciated man..... now to find why the crap the pedal does not feel as hard as it used to on the EK4.  My money is on M/C...
		        		DLUG Racing
							holy crap!!! i think the pressure in my dc2 abs can break skin!!! its hard 2 control the spanner. nice write up! love the pics!
 ur a talent!
				Array
							thanks man
 did your DC2 have a hex nut or a square nut ??
 it cums out hard ay
 its hard to crack the nut and control your self from opening the nipple to much
 hmm this thread is going in the wrong direction, with words like come's, nipple, hard, control.
		You may not post new threadsYou may not post repliesYou may not post attachmentsYou may not edit your posts  Forum Rules |
