nice write up.
just a quick noob question, is the process pretty much the same for an auto transmission eg. 98 accord V6?
going to try and attept it this weekend if i can :s ... is there anything else i will need, new washers, filters etc..
thanks again for the great DIY.
 Originally Posted by Dray_Templar
nice write up.
Not the same for a AUTO FWD. You dont need anything else except a oil pan and a funnel of sorts ~ like the one DXS shows here.
All you do is drop the drain bolt , let the fluid flow out. Once it stops , replace the drain bolt and take out the dipstick (on the gearbox). Fill this up with the recommended amount , and test the level with the dipstick gauge.
BTW check my thread below on how to make the filler and fill easy
http://www.ozhonda.com/forum/showthread.php?t=58596
thanks a heap bennjamin you a life saver
Great info! Unlike changing engine oil, the transmission oil only needs to be changed every 40000kms if you follow the maintenance schedule or more regularly if you like to take care of your ride.
Dray_Templar, don't forget to use new crush washers! It'll save you having to do the bolt up donkey kong tight and prevent any leaks. On the D-series tranny it's drain plug 39Nm (29lbsft) and 44Nm (33lbsft) on the filler plug if you're anally retentive like me and everything needs to be done up right.
On a completely different note, Dxs, that blue bar underneath your engine connecting your lca mount points together, what is that and what does it do?
Project Civic777 - obsession for achievement
Looks like it's a front lower tie bar.
It's for cars with an independant suspension, and helps to strengthen the subframe.
It'll help your handling through corners, as well as reduce torque steer and wheel hop. (In a FWD, anyhow)
 Originally Posted by mugeneration
Well I always thought to PLEASURE your girl was anything sexual.
To PLEASE your girl is anything that costs money.
thats good DIY il try dis weekend, thanks
nah 40,000km is quiet long.. average is 20,000km but i change mine every 10,000 to keep it in good nick.
Agreed, 40000kms is what interval a grandma would get it changed cos that's what the maintenance manual says, unless the grandma enjoys spirited street driving and track days! Kind of like how regular oil change is scheduled for 7500kms but I dare say most people change it every 5000kms here. No harm done changing it more regularly, for sure.
thanks muhhan, as always ozhonda members are the best
just a Quick one was told that Mitsubishi's Auto Tranny fluid is 98% the same as honda's, and seems to work as well as honda's , and can be used in a pinch when honda's, isn't easily available. let me know what you guys think
cheers and thanks again ppl
awesome.
funny too
i think my gearbox hasnt been flushed in ages...
with flushing... how should i go about it??? just keep on filling up the fluid a few times and getting any shit out???
Got an old Videogame console, handheld, games and accessories. PM me! I want them
