DIY: Throttle Body Cleaning
Comment:
Possible problems experienced due to excess Carbon and oil buildup:
* The engine stalls when idling, especially when using A/C.
* The Idle revs sit below the standard idle rev level.
* Intermittent Rev hunting during idle.
* Small loss of overall engine power and smoothness.
NB: If the engine is revving too high (for instance 2000RPM+ when cold, 1500RPM+ when warm) or experience other eratic idling problems, you may need to clean out the carbon deposits in the IACV screen, and/or screw back in the FITV plug (D-Series engines).
[Search OzHonda for more info]
Engine pictured is a D16A8 (ZC) non-VTEC.
Aim:
To remove contaminants in the throttle body.
Required:
Plyers
Phillips-head screwdriver
A Can of Carby/Throttle Body Cleaner
Spark Plug Remover (optional)
An old shoelace/rope of about 1 meter
A Throttle cleaning Kit which should include a long Snake-like cleaner.
(You can use an old Toothbrush and a clean rag, if you done have a snake).
Park the car outside when doing this.
CAUTION: When you are spraying in the Throttle Body, be careful that the plastic nozzle extension on the Can does not fall off and down into the Intake Manifold! Same with the toothbrush or any other loose object!
Step 1 - Air duct removal
Turn off the engine, apply the handbrake, put the gear in Neutral.
(1) Loosen the Ring around the Air Duct using a Phillips-head ScrewDriver.
(2) Disconnect the Sensor Electrical Plug. Its probably a good idea to unscrew and remove the sensors, as they can be damaged by the Carby/Throttle cleaner. But on my engine, the sensors didnt pass all the way through into the throttle body.
(3) Unclip and remove the Idle Bypass Pipe - Air Duct Side.
(4) Unclip and remove the Idle Bypass Pipe - Engine Side. Move this pipe out of the way if needed.
Note: The location of the FITV is shown in blue incase you need to work on that another time. Leave it be for now.
Unscrew and remove the Air Filter Cover to properly remove the duct:
Now pull out the Air Ducting and put it aside. While it's out, you should check it for dirt and cracks, and clear out the small tube. If the small tube has a dirt buildup, you may have a damaged Air Duct or your Filter needs replacing/cleaning.
Step 2 - Cleaning the Throttle Body using Carby/Throttle Body Cleaner
There are a few ways of doing this, its a matter of personal preference.
If you are a n00b at DIY work, then simply follow choice A.
Choice (A) = Car OFF -> Clean -> Car ON (Quick and easy but dirty)
- This involves cleaning the throttle body while the engine is off, re-assembling everything, then running the car for 15-30 minutes while all the crud passes through the engine. The car will be hard to start and will bog alot because all the crud has flooded the Intake Manifold.
Bogging the engine wont necessarily harm the engine, and this technique is actually the "normal" way according to some sources (i.e. manufacturers of Carby/Throttle body cleaners).
Choice (B) = Car ON -> Clean while ON (Quick but can be tricky and risky)
- This involves cleaning the Throttle Body WHILE the engine is ON.
The problem with this is its hard to clean the inside of the throttle body properly because the engine will RedLine if you open the Throttle Plate too far. But its good because the engine wont bog as much, since the crud will be passed through the engine gradually instead of all at once. If you want to do a major clean then this choice is not really suitable. Another downside to this is that dirt flying in the air may be sucked into the engine and possibly cause damage!
Choice (C) = Car OFF -> Clean while turning the engine (More work, but can be cleaner)
- Recommended by user 'iamhappy46' :-)
This involves removing the spark plugs, disconnecting the ignition coil wire/plug and prevent the motor from hydrolocking when flooding the motor with carby/throttle body cleaner. Doing it this way will also clean sludge off your piston crowns. Your can turn the starter motor over (it won't fire) while spraying the TB out as well.
Choice (A)
While the engine is off, rig open the Throttle Plate so it stays wide open (see pic below). You can do this by tying a Shoelace or rope around the Throttle Spring/Lever, pulling it so the Throttle Plate opens completely, then tying the other end to a strong metal object opposite the throttle body. I used the drivers side suspention bolt.
Spray and clean the inside of the Throttle Body using the Carby/Throttle cleaner and a Toothbrush + Rag, or use a Throttle Body Snake Cleaner designed specifically for this job.
Let it dry for a minute, then give it one last spray to release the residue.
Alot of contaminated Carby Cleaner liquid will go into the Intake Manifold, but dont worry.
Reconnect everything (reconnect the hoses, air intake, and sensor plug) and get into the car.
Now here is the fun part.
Due to the dirty carby liquid flooding the intake manifold, the car will be quite hard to start and will complain and chug alot for a minute. Dont worry, ignore that sinking feeling in your gut lol! It will start eventually.
You may need to hold the revs at around 2000RPM+ for the first few minutes while all the crap passes through, otherwise the engine will bog and stall alot. Ignore the huge white cloud of smoke coming out of the exhaust
Once the engine can idle by itself, leave it idling until the white smoke stops.
Choice (B)
Turn on the engine. While the engine is ON, slowly spray and clean the inside of the Throttle Body using the Carby/Throttle cleaner. You will need to partially open the Throttle Plate by turning the Throttle wire spring with your fingers. But beware that the engine will rev very high if you open the plate too much, which is not a good thing to do for long periods, and revving high while carby cleaner is entering the engine may be a concern. If you want to just do a major cleanout and use the Snake or Toothbrush, then it may be easier using Choice A or C.
Some contaminated Carby Cleaner liquid will go into the Intake Manifold, and the engine may choke a bit, or even stall if too much Carby cleaner goes down at once. If the engine begins to stall, open the Plate to increase the revs a bit.
Once done cleaning, turn off the car and reconnect everything (reconnect the hoses, air intake, and sensor plug). Then turn the car on and idle the car until the white smoke stops (if it is smoking).
Choice (C)
NB: I have not tried this personally so I can't go into much detail with pics etc. If you would like to add more detail, let me know and i'll update it.
While the engine is OFF, remove the spark plugs (or simply disconnect the Spark Plug Cables?), and disconnect the ignition coil wire/plug.
Clean the Throttle Body as like in Choice A. Once you have done cleaning, get in the car and turn the engine over for maybe 30 seconds. If you wish, you can turn the engine occasionally while cleaning the Throttle Body.
Note that cranking the engine uses alot of battery power so you should ensure your battery is in good condition.
Reconnect everything (reconnect the hoses, air intake, sensor plug, spark plugs, ignition coil/wire) and get into the car. Start the car (it may stall or complain a bit attempting to start, but not as much as Choice A) and idle it until the white smoke stops.
Also, make sure the cleaner is O2 sensor friendly. Read the description as some can kill your O2 sensors.
nice and detailed write up
19inch SSR Visconti Wheels & Tyres For Sale and D2 Coilover for Accord. PM for detail
how do u clean the o2 sensor?? and where is it???
Got an old Videogame console, handheld, games and accessories. PM me! I want them
Its usually at the front drivers side near the oil dipstick (its a metal cylinder with a wire coming out from the end). I don't think you can clean it, you need to replace it.
just having a little trouble cleaning mine
got most of the junk out, now reassembled the intake and tried to start the thing
it cranks over once then stops and beeps at me
is it safe to continue doing this or did i screw up a simple procedure?
edit; nevermind, one of my cylinders were too flooded to start, sucked all the carby cleaner out and it started fine
very noob question, with this cleaning, is it possible at all to cause a hydrolock scenario ?
if not then I guess there was no need to suck out the solution from the engine as vinny did ?
Ive never heard of any damage happening. During the initial cranking, most of the carby cleaner should exit through the exhaust before the engine actually starts up (which takes longer than usual obviously). Cranking is run off a 12v electric motor rather than the powerful force of combustion, so it should be fine.
If you are worried about it, simply remove the spark plugs so the cylinders can breath and avoid a hydrolocking scenario.
If you don't know where it is....probably not best to even try cleaning it
oh not bad something to do when there's nothing else to do! nice write up dude!
any1 else had dirty TB?? if youre gona clean it, take some pix... and see if its as dirty as mine...
