Page 1 of 2 12 LastLast
Results 1 to 12 of 24
    Apr 2006
    Melbourne
    NEED DC2
    Please help!!! Wet carpet
    i have had my car since jan and nothing has been wrong with it, perfect car mechanicaly interior is smich and i couldnt figure out why i picked it up for such a steel
    i have only just realised after i finaly got around to giving my interior a vacume that my driver side carpet is wet...i never realised because i have floor mats that are rubber backed so it has never come through to my mats
    i lifted the carpet today and the water is coming from what looks like rubber covering with a foam backing which is pretty much under the pedals to where your toes would sit...it is cracked in some places and the water is seeping through the soaked foam and onto my interior carpet
    this is only on the drivers side and is not to bad yet but i want to attck it now while the weather is not that bad and before my car smells water damaged
    anybody help me let me know what the rubber surface is there for, if its happened to anyone tell me what you did
    please help!!!
    u got a sunroof?
    i got similar probs too but in an ls
    so anyone help him can kill 2 brids with one stone
    Green block gangster Array
    May 2004
    twin GX160's
    get the hose out and get someone to run water onto your sunroof, then look under the dash to see if its coming from that hose.
    if so replace/repair that hose
    May 2005
    Sydney
    Honda Beat
    the rubber surface is there as deadening to keep out noise and heat from reaching the cabin
    Apr 2006
    Melbourne
    NEED DC2
    Quote Originally Posted by TRU32U
    u got a sunroof?
    Quote Originally Posted by ECU-MAN
    yes i have a sunroof...ecu-man can u expand on what you said to do, i dont quite understand what to do with the hose.
    are you talking about a hose in the car or garden hose???
    this sounds like it could be it if tru32u has the same prob and a sunroof, if anyone could help some more it would be greatly appreciated
    May 2004
    twin GX160's
    sorry
    you get someone to pour water on the sunroof with a garden hose
    while your in the car looking for the leak,
    as you said you saw it leaking from that hose, replace or repaire that hose. make sure your windscreen isnt leaking.
    Apr 2006
    Melbourne
    NEED DC2
    if it were the windscreen would it still leek onto the floor of the drivers side??? how???
    i never said a hose, what hose could it be and where is this???
    when i lifted the carpet there is what looked like a rubber gromet, do you know what this is???
  8. #8
    May 2004
    twin GX160's
    yeah the car has several gromets,
    best get a torch so you can see and the hose on it.
    water will find its way to the carpet no matter where its leaking from,
    on a 4 door I have seen the rear door causing the drivers floorwell to get wet,
    look in your kick pannel, you will see a hose that goes up the A pillar, this is the sunroof drain, make sure ist ok and not leaking.
    sometimes to find a leak you just have to spend a bit of time to find it with a hose and someone crouched under the dash with a torch looking for it.
  9. #9
    Apr 2006
    Melbourne
    NEED DC2
    im new to this, so could you explain it noob style...kick panel and a frame??? where do i find the drain for the sunroof???
  10. #10
    Jun 2005
    Melbourne
    93 B16A DA9 Integra
    i had the same problem with my old LS
    spent 2days with a hair dryer dryin it up... havnt used rubber floor mats since. my theory is that the water got in there a over a week b4 i discovered it, as it was raining, and the my jeans/shoes got drenched. the rubber mats kept the moisture in there for a while... didnt have wet carpet since that although it did rain several times
  11. #11
    Apr 2006
    Melbourne
    NEED DC2
    Quote Originally Posted by wkdteg
    yeah i like the rubber mats though, my ones are so thick and soft
    did you fix the leek or did you just chance it and it never happened since???
  12. #12
    Jun 2005
    Melbourne
    93 B16A DA9 Integra
    i took the chance... assumed it was from me opening the door to get in when it rained, as well as my feet being drenched.
    my car is parked outside... and once i got rid of the floor mats, it neva happened again.
