after searching i couldn't really find a proper DIY CTR headlight IN Ozhonda, just links redirecting to other websites so i thought why not do one just for Ozhondafirst write up, we see how it goes or and exuse the camera phone photo quality
AIM: Create a copy look-a-like Civic Type R style headlight and save you 300 odd bucks
TOOLS:
-/ Colour spray of the choice you want
-/ alcohol hole and towel
-/ Heater, blowdryer
-/ Oven if you wish (i didnt use it cos the first time i did, it melted my light)
-/ Screwdriver flathead and philip head
-/ Selleys all clear water resistant silicon seal
-/ someone yo assist you would be great too (my 10yo bro)
-/ Patience y0~!
STEPS:
1/ Remove front bumper by remove the 5 plastic clips on top of bumper, 1 on each side of bumer in the fenders and 2 below the bumper. NOTE: dotted lines mean its UNDER the car and CANT BE SEEN!
2/ remove headlight. i did left one first. there are 2 screws on top. 1 on side (can be seen easily after removing bumper), and 1 on right just inside the grill area. NOTE: dotted circle mean its UNDER the car and CANT BE SEEN!
3/ seperating the headlight. Place headlight seal towards the heater for approx 10mins (depending on tempereture of heater) and see if it melted the silicon. TIP: its good to use your flathead screwdriver to make alittle gap first to allow heat to get in.
NOTE:i decided to use a heater instead of an oven because last time i tried oven it almost melt my headlight. Also the heat from the heater was only hot enough to soft my silicon and not melt the plastic. Ofcos you may want to try it at your own risk. (150-220 degrees preheat and check it every 2 mins)
because i used an heater i can not heat the whole headlight at the same time, i had to open the headlight bit by bit. Initial opening is the hardest process but it gets easier and easier as more gap is opened. here is some tricks i used.
use a 10cents piece and put it in between to gap so the silicon wont stick back into place. then put it back infront the heater to soften the next part.
you could also use the screwdriver to open up small gaps at your own risk.
here is what it looks like when its all seperated.
4/ remove the chrome housing. unscrew the two philip screws from the plastic housing and remove it. (its obvious where they are, so no photo here. make sure they are TWO!)
heres what it looks like when its seperated.
5/ remove chrome. use alcohol and rag to rub all areas you wish to paint. rub it for awhile till chrome starts to fall off. they are alternative methods here also. up to you. if your lazy just paint it straight away![]()
1st up a light coat, then wait till its dry then reapply a heavier coat. do 3-5 times or until you reach the desire colour you want. i just did black for maximum contrast between my white car. however dark gun metal grey is a nice choice also. you may wish to apply clear coat here also if you want the glossier look, but i prefer matt finish so i left it.
6/ put it all back together with a good silicon. i used Selleys water resistant to also keep the water out. let it dry and put it back onto your car.NOTE: before sealing it might want to check both headlight for dirty inside the lense and whether if both colour paint is the same shade.
BEFORE:
AFTER:
~THE END~
