							Ok - so it may be pretty dam self explanitory...but from recent and achived discussion...it seems some users seem to not even be able to change their underpants...let alone their cars oil !
 Aim : To simply change you vehicles oil at the 5000km reccommended intervals ! Why pay $100 to change it when all it SHOULD cost is $25 for oil and a 30c washer ? Look on......
 Required : 1 x container of preffered engine oil , 1 x new OEM honda "sump plug" washer , 1 x "sump nut sized wrench" and a small funnel.
 Steps :
 Let your engine idle for a few minutes to circulate the oil throughout....then turn it off.
 First , make up a disposable oil-container - either a tray or cut out a old container- which can be re-used for future oil-changes !!!
 Next , pop bonnet , and unscrew the oil cap ontop of the cam cover.
 Now , lay under the front of the car , locate the sump , and locate the sump plug
 Position yourself , and the oil catch container underneath the sump , and position your tool onto the bolt head
 Contain a good grip, preferably one hand upon the bolt head/tool shaft , and one upon the end of your tool - and slowly but firmly release the bolt.
 After a few good turns , the bolt will begin to loosley sit - Take your tool away , and hand loosen - preparign for a mass of yucky oil ! *Wear gloves people ! Used oil can give u skin cancer!*
 Let the oil drain until one or two drops every minute or so - then take sump plug and replace the washer with a new OEM honda item
  Place plug with new washer back into hole , and hand tighten (with tool ofcourse)to a firm torque. Do not over tighten, as it may pre-stress the washer.
 Next , get back up of yo ass - and place a funnel into the fill hole -
 fill with your reccommended amount of engine oil - about 3 litres or so. . .
 Screw the lid back on , dispose of used oil properly , and turn on car.
 Let it idle for a minute or so - then turn off.
 Check around sump for any signs of leaks , and check oil level upon dipstick and add/take away oil if needed.
 And done !
 Remember , every 5000kms you should change your oil - and every 10,000kms change both your oil and oil filter ! Easy !
		You may not post new threadsYou may not post repliesYou may not post attachmentsYou may not edit your posts  Forum Rules |
