We are Australian Official Authorised Distributor for Hasport products since 2006
All Hasport mounts purchased from JDMyard came with lifetime warranty against defects.
Pm or email : yonas@jdmyard.com for best prices and any HASPORT product enquiries.
We will match / beat other Australian Hasport dealer / reseller with ABN
88-91 Civic & CRX
EFB1
88-91 EF Civic & CRX B series swap engine mount kit with cable clutch transmission ( Not to suit Jdm EF8 and EF9)
EFB2
88-91 EF Civic & CRX B series swap engine mount kit with hydraulic clutch transmission ( Not to suit Jdm EF8 and EF9)
EFSTK
88-91 EF Civic and CRX standard replacement engine mounts ( D series )
EFK1
88-91 EF civic and CRX K series swap engine mount kit
EFKALT
Alternator relocation kit for K series engine swaps , A must for EF and optional for EG/EK/DC2
CMA
Clutch master adapter allows the use of Honda style or Wilwood style of clutch master cylinder to convert
a cable transmission into hydraulic transmission set up.
EFBAX
Level 1 Axle set
Complete custom axles for the 88-91 Civic/CRX with B-series swaps and cable transmission, and the SK7 intermediate shaft.
EFBAX-Y
Level 1 Axle set
Complete custom axles for 88-91 Civic/CRX with B-series swaps with a cable transmission and the Y1 intermediate shaft.
92-95 EG Civic / 92-97 Delsol CRX / 94-01 Integra
EGSTK
Performance mount kit for use with the stock D-series engine (with 2-bolt left-hand mount bracket) and transmission in the 92-95 Civic and Civic Del Sol. These mounts will also work with B-series engines with 2-bolt timing left-hand mount bracket.
DCSTK
Performance mount kit for use with the stock B-series engine (with 3-bolt left-hand mount bracket) and transmission in the 94-01 Integra. These mounts will also work with D-series engines with 3-bolt timing left-hand mount bracket.
EGWK
92-95 Civic / 92-97 Delsol CRX /94-01 Integra K-Series Wiring Sub harness
EGK1
Performance mount kit for K-series engine swaps into the 92-95 Civic and all years of the Civic Del Sol and 94-01 Integra After making some modifications to the engine bay, this mount kit makes swapping the K-series engine into the EG Civic and Civic Del Sol a bolt in procedure.
EGKAX
- Brand new Level 1 Axle set for use with K Series engines
- 95-95 EG Civic 96-00 EK Civic 94-01 DC2 Integra 94-97 DelSol
- Hasport Axles are made from completely brand new parts and do not require a core like many other competitors do.
- These axles are rated to handle up to 200 horsepower at the wheels.
- Hasport also offers axles for higher horsepower applications please call for more information on these special order axles.
EGH2
Performance mount kit for F or H-series engine swaps into the 92-95 Civic 93-97 Civic Del Sol and 94-01 Integra. After making some modifications to the engine bay, this mount kit makes swapping the F or H-series engine into the EG Civic and Civic Del Sol a bolt in procedure.
EGHAX
- Brand new Level 1 Axle set for use with H/F Series engines **work with EGH2/EKH2 mount kit**
EGK3
Performance mount kit for K-series engine swaps into the 92-95 Civic and all years of the Civic Del Sol. After making some modifications to the engine bay, this mount kit makes swapping the K-series engine into the EG Civic and Civic Del Sol a bolt in procedure.
This kit is designed to run with Accord Euro CL9 six speed transmission
96-00 EK Civic
EKSTK
-96-00 EK Civic engine mount kit for B/D series engines (2 bolt style left mount)
-Engine mount kit for B and D series Engines. Fits B18B, B20, and B16 engines. B18C/1 or B18C5 requires a bracket change.
EKH2
Performance mount kit for F or H-series engine swaps into the 96-00 Civic.
EGHAX
EKK1
This is the first of two performance mount kits for K-series engine swaps into the 96-00 Honda Civic. This mount kit designed to work with the stock front suspension subframe and makes swapping the K-series engine into the EK Civic a bolt in procedure.
EKK2
This is the second of two performance mount kits for K-series engine swaps into the 96-00 Honda Civic. This mount kit designed to work with an EG/DC rear cross member, lower control arms and steering rack. Using this mount kit the engine is moved back resulting in better axle angle, protection from contact with the ground and better weight distribution. This kit has dual height mounting points so the engine can be mounted for better power steering pump clearance to the hood.
EGKAX
EKWK
96-00 Civic K-Series Wiring Sub harness
2002-2005 Civic Type R EP3 and 02-06 Integra Type R DC5
DC5STK
- Stock replacement mount kit for the 2002-2005 Civic Type R EP3 and 02-06 Integra Type R DC5
- Eliminates wheel hops problem on DC5/EP3 chassis, prolong axle life.
Replacement Urethane
Pair or replacement urethane for an individual mount. To replace an entire kit order three pairs.
Available in four durometers. The higher numbers increase rigidity and limit engine movement.
from 62a Street to 94a Most Extreme Race
Warranty information
What is covered
This warranty covers any defect in materials or workmanship in your HASPORT engine mount kit. ("engine mount")
What is not covered
Damage to the engine mount that is caused by abuse, misuse, modification, or excessive force being applied to the engine mount (such as crashing your automobile). Consequential and incidental damage (such as damage to your automobile if the engine mount fails) are not covered. Some states do not allow this exclusion or limitation of consequential damages, so the above limitation or exclusion may not apply to you.
How long coverage lasts
This warranty lasts as long as you own the engine mount.
What HASPORT/JDMyard will do
HASPORT/JDMyard will repair or replace the engine mount if it is defective at no charge. HASPORT/JDMyard is not responsible for costs or removing or re-installing the engine mount. or postage
What you should do to obtain service
You must return the engine mount to JDMyard for inspection and pay the shipping cost for the return. Proof of purchase is required when obtaining warranty service, so you should include a copy of your invoice or other proof of purchase. If an engine mount is defective, HASPORT will repair or replace it within 30 days of receipt.
