					DIY - 22mm dc2 swaybar on da9
 aim: to install something thicker than the 18mm swaybar that whiteline make specifically for da9 - ie the 22mm dc2 item
 tools required:
 socket set
 jackstands
 jack
 HEX KEY - DO NOT START THIS IF YOU DONT HAVE ONE!
 packing grease
 22mm whiteline swaybar kit for dc2 (der)
 big mofo drill (ie not cordless)
 steel drill bit
 method:
 1) loosen your wheel nuts when the car is on the ground
 2) Jack your car up using the beam running from your tow hook
 3) remove your wheels
 4) remove the mounts for the stock swaybar closest to the rear of the car - there are two bolts for each one, and they are the highest mounting points for the bar. unless you are planning to return the stock bar to the car, you'll never need these parts again. ever.
 5) remove the bolts holding the swaybar to the lower control arms
 bit of a comparison...
 6) remove the lower control arm bolts. again, if you dont plan to restore the car to stock you wont be needing these again. they can be mofos to get out, and you will most likely find that you after unscrewing them you need to put a screwdriver in the other end and bash them out. if in doubt, hit harder
 7) line up the mounting plate with the protrusions pointing towads the front of the car. mark the two spots where you have holes on the mounting plate, but not on the subframe. its about to get fun
 8) i used an 8mm drill bit, but size up and use whateve ryou think is best, my holes were probly slightly too large, but hey. drill the two holes - this could take a while as its quite thick in places
 this is what your new holes will look like - this is travs pic and i take no credit for it whatsoever
 9) once youve drilled the holes, put the mounting plate on and just check that all the bolts slide in ok
 10) using the new lca bolt ( the hex head one) install the mounting plate, then a washer, then through the subframe and lower control arm. when doing this its necessary to support the hub assembly with another jack, or similar so that the lca lines up and you can put the bolt through. i
 initially, i put the jack under the very end of the lca, with the hole in it, then once i had the bolt in, i put it right over the other end, towards the brake disc, and bashed it in
 now you'll need to put nuts on the end of the bolts which have gone into your brand spanking new holes (the ones you drilled). this is easier said than done, as their aint a lot of space up there. once i got them on, which took some sweet time, i held the nut with a spanner and rotated the bolt with a socket attachment
 11) get out your packing grease, and smother the yellow bush with it
 12) slip the bush around the swaybar, and grease the outside of it
 13) put the gold bracket over the bush, and grease the outside of that too
 14) put the gold U shaped bar over the bracket, and through the holes (with a washer before the holes
 15) once youve done this, get a mate to support the swaybar while you push the U shaped bracket through the holes on the mounting bracket.
 16) put the nuts on loosely
 17) now its time to attach the ends of the swaybar. you will find two holes - ideally you want to attach the one which allows the gold bracket to sit as vertically as possible. the holes closest to the back of your car will give the stiffest feel, and better performance (marginally)
 for the end attaching to the lca, you will not need a nut, as the bolt screws in. for the end attaching to the swaybar, you will, because it doesnt
 18) easily the most time consuming part for me was doing up the nuts on the U brackets, going over the swaybar itself, because you just cant get a socket in there. i suppose you could install them first, but that would make things harder when tightening the mounting bolt nuts.
 19) make sure everything is nice and firm, then lower your car and drive. feel the stiffness!
 nb: due credit to string, without whom i would never have thought to try this
							forgot to add: big thanks to Trav (Egsi) for supplying this kit, and giving great service, always keeping me up to date with the order, delivering quickly, and doing the DIY i based my installation on! truly was a pleasure doing business with him
							wow man, u did it  shit yeah. i cant believe how easy it was. just do me a favour, clean up that tired muffler LOL!
 any intial driving impressions?
							very nice stuff dude. it looks complicated esp with the drilling of the stock bits but aweseom stuff
							That's great work man. Props for trying something like that.
							driving impressions are that its FKING SWEET.
 basically you feel as though there is loads more control over the front end when cornering - i can turn in harder, and with more speed, yet feel like i am way more in control.
 also when the front does start to break away, its more linear - ie rather than massive understeer all of a sudden, its much easier to tell when youre approaching the limit.
							hey mr will did you have the 18mm installed first??i want to know what that felt like before installation of the 22mm
					  Originally Posted by Steer^Gimic hey mr will did you have the 18mm installed first??i want to know what that felt like before installation of the 22mm
 no i had the stock 14.7mm one on. if i had had the 18mm one on, i wouldnt have had to drill the holes i did.
 why go 18mm when you can go 22mm?
 4mm is reasonably significant.
	which is why 18mm is a significant difference from standard 14mm. well done on the effort by all means, i personally wouldnt have gone through all the trouble as i think 22mm is too thick.
					  Originally Posted by Mr_will no i had the stock 14.7mm one on. if i had had the 18mm one on, i wouldnt have had to drill the holes i did.
 but well done, looks great
							i have a question for you, why did u choose to go with the dc2 bar, why not the dc2r bar? correct me if im wrong but is it not easier to get the type r sway bar onto a da9, and also would the fact that it doesnt use end links improve performance?
					  Originally Posted by Steer^Gimic which is why 18mm is a significant difference from standard 14mm. well done on the effort by all means, i personally wouldnt have gone through all the trouble as i think 22mm is too thick.but well done, looks great
 too thick for what? there is no downside - the da subframe is strong, so it can handle it. it has no detrimental effect on ride quality, and significantly improves corner speeds, with the reduce roll.
 there is no real need to go 18mm as opposed to 22m, unless youre too timid to install the 22mm one, which would be understandable.
 i didnt go the dc2r bar because it is designed for different lca's than da9 ones, thus would not fit on my car.
 as for the end links business, i think trav would be the best person to answer that question, as i really dont know
							good stuff bro, ill hopefully be trying it one day!
		        		The Pain Of Discipline Is Far Less Than The Pain Of Regret
		You may not post new threadsYou may not post repliesYou may not post attachmentsYou may not edit your posts  Forum Rules |
