We are now authorized Australian Distributor for full range of P2R products
Power Rev Racing founded in 2004, under the idea of establishing his brand name as a race industry leader. Power Rev Racing, marketed under the label P2R, strives to excel in performance. The parts offered are intended to keep you, the racer, competitive and in the winners circle. All parts are made using high manufacturing standards as well as top shelf materials. Throughout the year P2R competes and leads in many local events including autocross, road, and drag races. Our priority is to infuse our products with knowledge learned on and off the track, allowing you to step up and show us you're Power Rev.
Here are some of our P2R products We have in stock
P2R plastic intake manifold gasket
Thermal Intake Manifold Gaskets
Power Rev Racing intake gaskets will help reduce intake air temperatures by removing the direct connection of the intake manifold to the cylinder head. Made out of our proprietary heat dissipating material the P2R thermal intake gasket creates a thermal barrier that isolates power-robbing heat from traveling to your intake manifold through the cylinder head. Less heat soak means cooler air and more consistent power delivery.
Available for :
B series b16a/b18cR PR3 - Back in stock
B series P72 b18c vtir
D series ( SOHC engine only )
K series K20A
K series K24A (accord euro)
H series ( H22A)
F series ( F20C ) S2000
all in stock
PRICE $75 EACH PICK UP GST INCL
K20A PRB/PRC IM Intake plenum box
$170
K20A Throttle body thermal gasket
$50
B16A Throttle body thermal gasket
$50
K series RBC / RRC intake manifold adapter $120
K20A Billet Fuel Rail (Avail in : Gold/ Black/ Red / Polished)
$230
B16/B18 Billet Fuel Rail ( Avail in : Gold/ Black/ Red)
$230
Liquid filled Fuel pressure gauge (in PSI)
$50
Billet DC5 battery Tie Down $75
P2R K24 swap light weight engine mount bracket (to replace crv bracket)
$135
For other P2R product please PM me
