SRS Light always on? Could be attributed to the following:
1. Disconnection of SRS Circuit then ignition on
2. SRS bits n pieces are focked - you're focked $$
Most likely its no.1. I.e. do an audio AMP install, take your SRS enabled front seats out, disconnect SRS connector under the seat, turn the ignition on BEFORE reconnecting the SRS connector. Thats what I did![]()
Performing a standard ECU reset WILL NOT get rid of the SRS Light, hence SRS ECU Reset is needed.
This was performed on a 1998 - 2002 CG/CK Accord. I've heard it works on other Hondas as well. But not 100% certain.
Aim: To reset the SRS ECU
Required: Loose scrap wire to short the ECU
Steps:
1. Find the SRS connector under your dash. In the case of the CG/CK Accord (and probably for most other Hondas), its yellow with green wires. Look for the small yellow one (~1.5cm x 1cm).
2. Get two pieces of scrap sexeh wires and strip all ends. Insert into connector as such
3. Hold wires together and turn the ignition on to 2 clicks (the one before the engine turns on)
At this point, the SRS light will come on as standard
4. The SRS light will then turn off - KAZAMM!:
Take wires apart as such (SCHWING!):
5. The SRS light will come on AGAIN. Connect wires again.
KAPOW!
6. The SRS light will go off AGAIN. Disconnect wires.
BAM!
7. AT this point, the SRS light should flash twice - signalling completion of this SRS ECU Reset![]()
8. You can plug the connector back in* and turn the ignition off.
Other comments
This procedure took less than 10 seconds, cost me nothing and would normally cost $$ at a Honda dealer to do an initial reading then action.
*I was told by a Honda mechanic that this plug itself leads to nothing. I have kept it hanging loose - all good since then.
Reason for this DIY: Hasn't been properly documented yet and I had this problem. Good to have in DIY section for ppl who need this (like me)
Hope that helps boys and girls
Jeff aka SiReal
P.S. If your SRS light comes on again, ensure all SRS component connectors are 'connected', then do this again. If it comes on again after that, go straight to your Honda dealer. It could mean something in the system is focked = $$$$$SAFETY FIRST!!
SAFETY FIRST!!
. Good idea for a write up
