NOTE: The specifications listed below are only estimates and to be used to gain a rough idea. OzHonda in no way guarantees their accuracy and is not responsible for any errors that may have been posted.
DC5 Integra Type R
Release: 2001-2004
Engine: K20A2 2.0L DOHC i-VTEC, 147kW@7400RPM, 192Nm@6000RPM
Specific: CR 11:1, Redline@7900RPM, Cutout@8200RPM
Drivetrain: 6 Speed close ratio, 4.764 FD, Helical LSD (same as JDM)
Weight: 1160Kg (without Air Conditioning - Optional)
Brakes(F/R): Ventilated discs 300mm, sold discs 260mm rear, large single piston calipers/Discs, ABS
Suspension(F/R): Macpherson Strut/Double Wishbone.
Handling: Rear sway bar (19 mm), front sway bar (23 mm), front upper strut brace
Standard features: 2 Airbags, power windows/steering/mirrors, Recaro buckets seats, Momo leather steering wheel, aluminium shifter
Additional: Bridegstone RE030 205/55/16, Enkei alloy wheels (16x6.5), JDM bodykit/chassis
DC5 Integra Type S
Release: 2005-2006
Engine: K20Z1 2.0L DOHC i-VTEC, 154kW@7800RPM, 194Nm@7000RPM
Specific: CR 11:1, redline@8100, Cutout@8600RPM
Weight: 1230kg (including Air Conditioning - Std)
Handling: Rear sway bar (xx mm), front sway bar (xx mm), front upper strut brace
Standard features: 4 Airbags, power windows/steering/mirrors, leather seats, sunroof, 6 stack mp3 cd player
Additional: Bridgestone RE050 215/45/17, Enkei alloy wheels (17x7), same kit as JDM DC5S, also same as JDM DC5R minus rear wing. DC5S has upgrades to suspension geometry, stiffer sway bars both front and rear, thicker rear cross member, rear strut brackets have 3 extra connecting points on each side, revised front strut/chassic brace is bigger and stuffer, cams similar to JDM DC5R, stronger crank, revised spring and damper rates, additional engine bay reinforcing, quicker ratio for steering, larger brake master cylinder, larger diameter exhaust, lower NVH due to more sound deadening.
DC5 Integra Coupe
Released: Late 2001 -
Engine: K20A3: 2.0L DOHC i-VTEC, 118kW@6500RPM
Torque: 191Nm@4000RPM
Weight: 1,160kg
DC4 Integra GSi
Released: Late 1993-2001
Engine: B18B2: 1.8L DOHC, 107kW@6300RPM
Torque: 172Nm @ 5200RPM
Weight: 1146kg
DC2 Integra VTi-R
Released: Late 1993-1999
Engine: B18C: 1.8L DOHC VTEC, 127kW@7,300RPM, Cutout 8,200RPM
Torque: 173Nm@6,200RPM
Weight: 1,176kg
Drivetrain: 5 speed
Brakes(F/R): Ventilated Front Disks xx mm / Solid discs, ABS
Suspension(F/R): Double wishbone/Double wishbone
Handling: Rear sway bar (14mm), front sway bar (24mm), front upper strut brace
Standard features: Airbags, power windows/steering/mirrors,
Additional Info: VTEC engagement@4,400RPM, Secondary Intake butterflies open @5,800 RPM.
DC2 Integra Type R
Released:
Engine: B18C7 1.8L DOHC VTEC, 141kW@7,900RPM
Specific: CR 11:1, Cutout@8,500RPM
Drivetrain: 5 speed close ratio, Limited Slip Differential (LSD)
Weight: 1,087Kg (with A/C)
Brakes(F/R): Ventilated Disks xx mm / discs, ABS
Handling: Rear sway bar (22mm), front sway bar (24mm), front upper strut brace, rear tower brace (optional)
Standard features: Airbags, power windows/steering/mirrors, Recaro buckets seats, Momo leather steering wheel, titanium shifter
Additional Info: VTEC engagement@5700rpm, Detailed info 1
DA9 Integra
Released:
Engine: B18A1 DOHC 1834cc 96kW @ 6000rpm
Specific: CR 9.2:1
Torque: 170Nm @ 5000-5000rpm
Weight: Kerb Weight 1147 Kg
Drivetrain: 5 speed
Wheels: 14 x 5.5
Brakes(F/R):
Suspension(F/R):
Handling:
Standard features:
Additional Info:
Integra SX16
Released: 1986-1989
Engine: D16A3: 1.6L DOHC, 90kW@6500RPM
Torque: 142Nm@5500RPM
Weight: 1,020kg
Reason: New Info
